Valve Adjustment Process - 240Z
4 replies to this topic
#1 TDoherty
TDoherty
  • 55 posts
Posted 13 March 2016 - 05:04 PM
To the collective brainstrust!
Can anyone help me with a step by step guide for the above process?
I last did this around 38yrs ago on my then 1600 so need a refresh please.
Tks Tony
#2 Linton
Linton
  • 528 posts
  • Tagline:1976 260z 2+2 Sunburst 1989 300zx Z32TT 2+2 Black
Posted 13 March 2016 - 06:49 PM
there is a sequence if you use the repair manual, but I start at the front lobe and turn engine as each pointy end of the lobe is at the top adjust the clearance on that rocker, involves two complete turns of the motor to do all valves
#3 TDoherty
TDoherty
  • 55 posts
Posted 16 March 2016 - 07:34 PM
Hi Linton,
Many thanks for your feedback!
My repair manual really isn't clear on the process and only really provides the clearance measures.
I've done a bit more searching and reading which has sufficiently jogged the memory so tomorrow is the day.
Cheers Tony
#4 ilbert
ilbert
  • 184 posts
Posted 17 March 2016 - 12:59 PM
Another funny thing re valve clearances - all the 240 manuals I have show to measure between the cam and rocker, whereas the Haymes 260z manual shows to measure between the rocker and the lash pad.  I'm not sure where other people check clearance I do it at the lobe.
#5 Agno
Agno
  • 1,330 posts
Posted 17 March 2016 - 10:50 PM
I followed fellow VicZCar user Adam's guide on his blog and adjusted my valve clearances yesterday arvo... Super easy.
https://twofortyzee....tachi-su-carbs/
After reading his post I summarised the key points into a half page cheat sheet:
_________________________________________________________________________________________________
Cam lobe 1 pointing up = Adjust 1, 3, 7, 11
"             " 4 pointing up = Adjust 4, 5, 10, 12
"             " 2 pointing up = Adjust 2, 6
"             " 8 pointing up = Adjust 8, 9
14mm nut = adjusting nut
17mm nut = locking nut
Turning nut counter clockwise = loosens locknut or tightens valve clearances
Intake valves set at: 0.20mm cold, 0.25mm hot
Exhaust valves set at: 0.25mm cold, 0.30mm hot
Be weary that the locking nut can sometimes turn the adjuster when turned (therefore changing valve clearances) so be sure to keep the 14mm spanner on the adjuster when you touch the lock nuts!
Edited by Agno, 17 March 2016 - 10:51 PM.
