Project 260Z - Stages
260z Restoration Rb26
104 replies to this topic
#81 mspecr
  • 82 posts
Posted 08 December 2016 - 03:29 PM
Started tearing apart the 1/4 windows, now I not sure if this is standard ... but the tabs that secure the window to the frame have been welded somewhat roughly, surely these didn't come like this from factory ?... either way they still aligned with the body so I'm not overly too concerned.
Had a quick go at polishing the stainless trim which came out a treat, there are still some small minor imperfections but i guess they can be just buffed out with more time, just your standard buffing wheel and some autosol metal polish.
Now I have intentions of getting some tint done, would it be worth trying to clean / polish the glass now, or just give it to the glass people to clean up and let them do it ?.
th_20161124_122458_zpscu5jywjr.jpg th_20161124_122503_zpsqeolhiaw.jpg th_20161124_122507_zpsibsjosd7.jpg
th_20161124_141417_zpse1dxxbq1.jpg th_20161124_131159_zps74tr2dbh.jpg th_20161124_142710_zpsbcmbvmwe.jpg
Received back the items that got sent off for powder coating, again cant really complain about the quality.
th_20161130_140502_zpspjz8ztqa.jpg th_20161130_140509_zpslryhxjgu.jpg th_20161130_135425_zpsrr77vc0j.jpg
  • gav240z and PeterAllen like this
#82 mspecr
  • 82 posts
Posted 15 December 2016 - 07:24 PM
Got around to attacking the fenders this week using the TABCO replacement panels. There is a fair bit of work involved with doing this, which I clearly underestimated.
Things like the position of nutserts that are in in the kicker panels (tabco units) are not in the same position as the OEM, this threw the recessed fender bolt way off. I only realized this after i rebuild the inner support to the original position.
The bottom folded lips have walked off during manufacturing, that it forced the panel to sit a good 5mm proud off the kicker panel, so had to slice the lower lip to bring it back in so it hugs the kicker panel.
And lastly it was around 5mm too short leading up the wheel arch, which again had to be sliced and filled. I think this was probs due to me folding the lip at the door end, thou i just followed the existing fold, so I'm not too sure :s...
th_20161206_142355_zpsssv6ivbh.jpg th_20161206_140209_zpsqzybmycv.jpg th_20161206_140207_zpsvhyot59i.jpg
th_20161207_095551_zpsdslll6an.jpg th_20161206_151352_zpsxryqwoav.jpg th_20161206_165729_zpscv6o7wio.jpg
th_20161207_102751_zpsicby7uk1.jpg th_20161207_103213_zps5tzxssej.jpg th_20161207_113641_zps3ullrvan.jpg
th_20161207_104033_zps6xytgthi.jpg th_20161207_104050_zpsdxfq0cxt.jpg th_20161207_115531_zps6vvepvnl.jpg
th_20161209_101058_zpsdeakrey2.jpg th_20161209_094844_zpsifiegrut.jpg th_20161209_101048_zpszaqee1tg.jpg
th_20161213_143429_zpsznjl73co.jpg th_20161213_143448_zpsws4bq60j.jpg th_20161213_140646_zps0zyuud1r.jpg
Still lots of cleaning up to do but you get the idea.
#83 gav240z
  • 13,098 posts
Posted 15 December 2016 - 08:07 PM
I love some of the work going on in here, thanks for making me realise how little progress I've made of late.
RE: Aftermarket replacement parts I've heard they can be a fair way off. For that section on my car I just fabricated it, it's a basic curve really. But if you don't have a roller it's probably easier to buy them.
The welds on the 1/4 windows are probably because the tabs have a habit of breaking off, on #150 I've got that problem on the driver side glass.
You can also polish stainless with steel wool and WD40 works well.
#84 mspecr
  • 82 posts
Posted 16 December 2016 - 12:22 AM
Cheers Gav,
Reading about the top end rebuilds you do and others on this forum is whats been guiding me through all of this, a lot of late night reading.
Sadly i don't have access to a roller or bender, pretty much a hammer, grinder and a vice lol. Anything somewhat flat is easy for me, hit some sort of bend / curve I'm out, so the aftermarket panels is my go too.
For the 1/4 that makes sense, I might just get the frames painted inside only to hide them weld blobs, outside can stay polished.
#85 mspecr
  • 82 posts
Posted 16 December 2016 - 01:15 AM
Fender (continued...)
Passenger side was pretty much the same deal as what I did with the drivers, thou this time the recessed fender bolt support / stiffener was aligned 1st, then connected to the fender, still a work in progress atm.
Also noted this fender didn't have a original cut out for the front indicator, so this means the entire passenger side of this car is not original at all... might start calling it two face soon.
th_20161214_122227_zps3e2jzumm.jpg th_20161214_122239_zpsa2adklod.jpg th_20161214_133548_zpsb1udpr21.jpg
th_20161214_152037_zpszcc9vt1r.jpg th_20161215_134402_zpsbv9vuayn.jpg th_20161215_140243_zpsdrrfg8sg.jpg th_20161215_143614_zpsly0mahtg.jpg
Sooooo.. Just when I was about to attack this with with a grinder, I some how managed to slice my wrist up against the bottom edge, It got me right between the glove and a long sleeve shirt out of all places.. bleeding stopped but if def a good clean cut, was half tempted to drop a depth micrometer in it to see how far it went .. the missus say its a stitches job however I beg to differ.. :s
To top it off, upon writing this i realized i still had the bolt holding the fender in place... which is now trapped behind the replacement panel and there is no hole to gain access too... lol sigh...
#86 mspecr
  • 82 posts
Posted 30 December 2016 - 05:35 PM
First up hope everyone had a great xmas ! and with the new year under 48 hours away hope it brings great tidings too all.
Carrying on i left the fender for the time being. Having engine parts laying around the house and running out of room the finance minister made it quite clear she is not impressed about the whole ideal.
Started off with washing down the block, knocked out the old core plugs and installed new ones. Quick lick of paint, installed slugs on rods, gap rings, threw in a set of bearings, check clearances, cleaned out the oil pump, installed new oil seals and knocked in a oil restrictor.
Head wise just cleaned it out, gasket match port for the exhaust and coolant on the intake,re shim buckets and installed some extended cam cap bolts.
Water pump and new timing belt with tensioner where also installed. Dialing in the cams will be done at a later stage.
th_20161012_085652_zpssnhvpgz1.jpg th_20161012_111550_zpsbtsc7agk.jpg th_20161013_121335_zpskkpxoabj.jpg th_20161013_133356_zpsarkmetad.jpg th_20161013_130652_zpsnag2dara.jpg
th_20161014_104947_zpshynzljfn.jpg th_20161013_155411_zpsbcwl7eyi.jpg th_20161013_155307_zps8w0t4tft.jpg th_20161012_104534_zpsfnxqqwgb.jpg th_20161012_133746_zpsx5a14xwd.jpg
th_20161012_143132_zpsfmjhsnsq.jpg th_20161012_144758_zpseox1jdmz.jpg th_20161219_174412_zpsee8su8yb.jpg th_20161219_180449_zpsiuvopacr.jpg th_20161219_181415_zpscyf8z9cz.jpg
th_20161221_182214_zpsetss01gn.jpg th_20161224_091400_zpsd5vnflge.jpg th_20161224_093131_zpslikxidou.jpg th_20161224_091808_zpswxbivw95.jpg th_20161224_123629_zpsbtjuqxol.jpg
th_20161224_114413_zps6rkakd5i.jpg th_20161228_143412_zpsnsounfs2.jpg th_20161228_102055_zpspgfdebj9.jpg th_20161229_135043_zpsbuiidbn3.jpg th_20161229_135213_zpsn7wrtymg.jpg
th_20161229_115457_zpsgqbt9t3b.jpg th_20161229_134025_zpsd4a2jgps.jpg th_20161229_134034_zpsjftf9jof.jpg th_20161229_134050_zpsrhyf3aoq.jpg
#87 mspecr
  • 82 posts
Posted 21 February 2017 - 12:49 PM
Yay back into it :D
So she been booked in for blasting, where I thought I was ready ended up 2 weeks of long nights in the garage, something always popped up and being somewhat ocd it had to be done.
Having a chat to the blaster they suggested to remove the majority of the under body deadener (something i dreaded doing in the first place) mainly as they worked on a hourly basis and is a lot cheaper in the long run.
So some of the works done where:
Welding un used holes in the firewall / engine bay area.
Re adjusting the A pillar again to match the corner where the windshield sits.
Removed rear antenna hole.
Finish welding the rear passenger 3/4 panel for good.
Remove under body deadener
Install and mod the Bad Dog Frame rails.
Stich weld gearbox and diff support brackets.
General grind down of forget welds.
I was going to install the rails after a blasting, however since I was removing the deadner anyways I ended up doing it. Worth mentioning you have to mod the ends of the rails that connect to the rear frame to clear the sway bar. 260 yes. not sure of this was a case for a 240.
th_20170206_102423_zpse6loqx6o.jpg th_20170207_111228_zpshedau7nx.jpg th_20170206_102426_zpscgjzr9tx.jpg th_20170207_111233_zpsqcceoeln.jpg
th_20170207_135205_zpsmiz2gjtx.jpg th_20170207_132654_zpsbzdcqu6w.jpg th_20170213_115706_zpsgl9x0nq4.jpg th_20170208_150942_zpsce1fadgl.jpg
th_20170213_115731_zpsgu3qwv3q.jpg th_20170214_184016_zpsqmdqq2ef.jpg th_20170214_184023_zpswbt1ylx3.jpg th_20170215_093911_zpsfbtj21nm.jpg
#88 mspecr
  • 82 posts
Posted 09 March 2017 - 11:00 PM
Being alone in a empty garage i turned my attention to my dash,  like most unrestored dashes these days mine had cracks just the same.
First thing was too open up the cracks so they are level with the surrounding surface, I used a die grinder with a pine cone, overkill for this but worked perfectly at carving up the old foam.
Next was to place some tape on the inside of the cracks that penetrated all the way through, this stops the expanding foam from filling the areas where there not needed. Apply expanding foam, using a a paddle pop stick i would smear the foam onto the walls to help it adhere, sit and wait for a hour or so till its cured.
Once cured, quick lick with 120 on a orbital sander to remove excess foam, normal body filler was used to fill the small holes in the foam, this was repeated until I was happy with the overall shape and con tore of the dash. Block sanded / feather coat and more sanding till i was up to around 600 grit, a final lick of high build primer and a last block to get it smooth.
Here on i drove it out to a mob out in Kelmscott, H-Tek Ultimate Coating, here we are going to get the dash flocked in black. Turns out he would also repair a cracked dash prior to flocking. ........ ... .. ... sigh.
Last pics is another client's dash that was just flocked in charcoal.
th_20170220_162005_zpsvfb2yllm.jpg th_20170220_162007_zpsgerdjeew.jpg th_20170220_162013_zpspzzm6ajx.jpg th_20170220_162226_zpsoy4yb4dh.jpg
th_20170220_163925_zpsofe42prn.jpg th_20170220_163920_zpsjwuhsx12.jpg th_20170221_093253_zpsafqkm6lc.jpg th_20170221_093305_zpsqyaujucu.jpg
th_20170221_093259_zpssonzuk56.jpg th_20170221_184114_zpsgse2th8m.jpg th_20170221_184351_zpsz2qrixe8.jpg th_20170221_184358_zps2hqrm4nu.jpg
th_20170221_184405_zpsrz9izrmd.jpg th_20170223_125158_zpsbnj51mwh.jpg th_20170223_153024_zps5fvmqxfp.jpg th_20170224_085613_zpsduokdnb4.jpg
Rear Lights.
While I was waiting for the foam to set i started attacking the rear lights, my lens where dull as you would expect for sitting around for so long, so a bit of wet sanding and going through the finer grades followed by a buffing wheel made them good as gold. I even removed the factory casting identification as polish would just get caught in the nooks and crannies of the lettering.
th_20170221_130926_zpspvn213ue.jpg th_20170221_131401_zpsm60rez9q.jpg th_20170221_131358_zpscfabwbo9.jpg th_20170221_134848_zpsccaxokfi.jpg
th_20170221_134856_zps3umucnev.jpg th_20170221_135456_zps0u6reqjb.jpg th_20170221_134346_zpsoxiqeiwk.jpg th_20170221_141553_zpssnqcfld2.jpg
  • gav240z likes this
#89 PeterAllen
  • 1,357 posts
  • Tagline:Manana!
Posted 10 March 2017 - 04:41 AM
Excellent, excellent, excellent build and thread.
  • gav240z and mspecr like this
#90 mspecr
  • 82 posts
Posted 15 March 2017 - 06:06 PM
1/4 windows ( cont  )
The frames where cleaned outed and buffed, however the inside of the frames where not to my liking, so a quick lick of satin black to help hide the unsightly welds from the mounting tabs. The glass itself was cleaned up using wd40, windex and a medium coarse steel wool.
Installing the 1/4 glass was a lot easier using ample amounts of dish washing liquid, the only hardest part i found was trying to get the new seals to match the corners of the seal to the frame itself.
After cleaning the frame down with water to remove all the washing detergent, I used contact adhesive to apply to the frame to the outer seal, masking tape was used to help hold the foam down while it cured, don't forget to install your corner trim / garnish.
th_20170307_154146_zps2szddps4.jpg th_20170307_154154_zpsmfg6fg01.jpg th_20170307_163442_zpscpxme4kb.jpg th_20170307_162411_zpswq1wtjkd.jpg
th_20170307_162416_zpsj2fknxkn.jpg th_20170310_123706_zpsogpgi8gt.jpg th_20170310_123700_zpsd2twkbke.jpg th_20170310_123711_zpsskfycttg.jpg
th_20170310_123828_zpsyh4hnfb3.jpg th_20170310_130742_zpsgpnh378w.jpg th_20170310_130931_zps4noyyde6.jpg th_20170310_125834_zpswzlkvdct.jpg
#91 mspecr
  • 82 posts
Posted 15 March 2017 - 06:12 PM
Pedal box,
Started to run out of room, and this was easy one to assemble.
2 bolts, 2 star washers, 2 plastic bushes, 2 metal sleeves, 2 rubber stops, 1 brake switch , 2 springs and 2 plastic spring locator bushes.
Clean out the threads of excess powder coat.
Grease up the metal sleeves and bushes and install.
Install tension springs,
Install stops and brake switch.
Final adjustment will come later for final pedal heights.
th_20170309_144045_zpsmqp5lo75.jpg th_20170309_144042_zpscqcujvfz.jpg th_20170310_121622_zpsygk0vlkr.jpg th_20170310_121632_zpsq3tydbjd.jpg
Edited by mspecr, 15 March 2017 - 06:18 PM.
#92 KatoKid
  • 1,741 posts
Posted 15 March 2017 - 07:42 PM
Loving this....keep at it!
  • mspecr likes this
#93 mspecr
  • 82 posts
Posted 15 March 2017 - 10:28 PM
Today I picked up the rest of the bolt on panels, I was surprised with how little damage over all considering how much work I had to do originally, I was expecting more.
The cowl panel had 1 pin hole, bonnet has one section about the size of a 50c piece and pitting around the vents, the lower valiance / indicator mountings was belted hard.
The rear hatch turned out great with only minor surface pitting around the lock and emblem area, other then that very minor dents here and there but overall I was pleased with the outcome.
The shell should be done by next week hopefully, then things will start getting interesting with temp fitting of new fuel / brake lines and engine / gearbox placement.
th_20170315_152703_zpsqvu3ojgn.jpg th_20170315_152657_zpsx0vwiuvb.jpg th_20170315_152954_zpsoq5hav4d.jpg th_20170315_152916_zpsrryfpsks.jpg
th_20170315_153100_zpsiti6mb5q.jpg th_20170315_153108_zpswsgt7fgz.jpg th_20170315_152833_zps7mnkufua.jpg th_20170315_152840_zpstcxl8edi.jpg
th_20170315_152744_zpszvm8yzet.jpg th_20170315_152723_zpsxqsn5qav.jpg th_20170315_152721_zpsdb2k6mmf.jpg th_20170315_152716_zpsp2auit7o.jpg
  • CBR Jeff and Rickers like this
#94 Riceburner
  • 3,272 posts
Posted 17 March 2017 - 12:29 PM
Looks very good after the blasting!
  • mspecr likes this
#95 Rickers
  • 132 posts
Posted 17 March 2017 - 01:44 PM
Should be labelled NSFW...
  • mspecr likes this
#96 mspecr
  • 82 posts
Posted 22 March 2017 - 06:28 PM
Inspection Light
A while ago i tore apart the inspection light and got the housing zinc'ed. New wiring, switch and lens were installed for this little beast. Pretty straight forward not much to really explain, only heads up is to pass the cable through the end lid first,then install your spring, bakelite washer then solder the tab..... don't ask why. Negative is soldered onto the J hook and your positive is the solder tab which is your base of the globe holder, here a piece of heatshink is used to tie the cable to the J hook to help support it when pulling it out.
At the other end your extension (speaker cable) the positive has to go to one side of the switch, this is not polarized so either tab will do. The other tab of the switch will be your feed or main supply in which was some red 1.5mm cable i had laying around. Heat shrink the ends for a pro look. Negative of the extension cable has to be soldered to a small clip thats folded over on the main housing. Pass your main feed through the hole in the base of the housing and rubber grommet it. Coil your extension wire into the housing and your set.
Switch Part No : ST0570 ( Jaycar )
Lens : 26oz (ebay user). http://www.ebay.com....=STRK:MEBIDX:IT
Wiring : speaker cable, unknown just what i had laying around.
Possible upgrades later:
LED globe.
Waterproof rubber grommet for the switch.
th_20161123_125218_zpsfwrcm7wk.jpg th_20161123_125254_zpst5j8hvzz.jpg th_20161123_125732_zpspdsyentb.jpg th_20170322_142855_zpsswxlf8lj.jpg
th_20170322_143555_zps0ezsqeuq.jpg th_20170322_143328_zpsrjiovlzc.jpg th_20170322_143807_zpsa1o7mitz.jpg th_20170322_144008_zpswtua9air.jpg
th_20170322_143958_zpsze8isefn.jpg th_20170322_144318_zpsjx0odjlx.jpg th_20170322_144505_zpsdakhjwkg.jpg th_20170322_153103_zps9l5q8xw3.jpg
th_20170322_153122_zpsnlnxt4sd.jpg th_20170322_153116_zpsvar5dx5l.jpg th_20170322_153244_zpsffjvrbuc.jpg th_20170322_153252_zpskckfkldj.jpg
#97 mspecr
  • 82 posts
Posted 22 March 2017 - 07:28 PM
Tail Light plugs.
After many hours of searching I was never able to really find a definitive answer in finding replacement bulb holders for the 260z tail lights. However if you have a stab in the dark you might actually hit something. So if you have a twist lock bulb socket that looks like the one below these are it.
Fitment is perfect with a solid locking detent, the only option was a pigtail type which is basically wires on the end. I do wish they where a tad bit longer but they will suffice. Wires are 105' deg rated 20 AWG, or .5 mm2 area and average 160mm long from the back of the plug. The globe itself sits in the same height with only the rear end being about 10mm shorter then original, No real dust seal that i can see thou with a tight fitment this shouldn't really be a issue.
Website : http://www.autolumination.com/
Part No : 1156 - Plastic Ba15s Single Circuit
Part No : 1157 - Plastic Ba15d Duel Circuit
Notes :
Pricing for shipping is expensive from this place...  However the range is huge, plus they have  wedge type twist locks too which can be interesting to use.
Qty to do both tail lights.
x6 : 1156 - Plastic Ba15s Single Circuit
x2 : 1157 - Plastic Ba15d Duel Circuit
th_20170322_164620_zpsmdvyigm8.jpg th_20170322_163902_zpsn8wijmss.jpg th_20170322_163807_zpsuevsts0q.jpg th_20170322_163532_zps2ipuisln.jpg
th_20170322_163612_zpsznomg5co.jpg th_20170322_163542_zpswobxwghl.jpg th_20170322_170430_zpscvr1mzwg.jpg th_20170322_171728_zps5cnyucuj.jpg
#98 mspecr
  • 82 posts
Posted 29 March 2017 - 06:59 PM
Blasting Part 2.
Picked her up today from the blasters, feels good to have her back. Over all she came out pretty good, only small pin holes here and there. The only biggest  issue  was that rear drivers side 1/4 panel around the tail lights, that was belted in at some point which i sorta expected considering how much bog that panel had originally.
I started calling around a few painters to get some idea on the timeframe / cost for final panel and paint, The colour I'm going with is from Hyundai ( I know.. I know...)  code S2G - Matte Grey Pearl, you find these on the Veloster Turbo models,  with the polished stainless trim should make it quite a clean look.
th_20170329_131046_zpsio4pbbrw.jpg th_20170328_151345_zps1tlnjzzt.jpg th_20170328_151131_zps6ovhmajd.jpg th_20170328_151605_zpsbfjpvj6p.jpg
th_20170328_151548_zpsogmtveay.jpg th_20170328_151546_zps6jhdtpl6.jpg th_20170328_151531_zpsevbddehb.jpg th_20170328_151500_zpsdxqtckwz.jpg
th_20170328_151338_zpstg7wts53.jpg th_20170328_151152_zpslnqtiavo.jpg th_20170328_151123_zpsaosomp8r.jpg th_20170328_151108_zpszlubayib.jpg
  • PeterAllen likes this
#99 PB260Z
    Peter (PB)
  • 3,314 posts
Posted 05 April 2017 - 08:53 PM
That shell looks incredible, one of the better ones around I would say.
Looking forward to seeing the SG2 Grey, should like really sharp.
  • mspecr likes this
#100 mspecr
  • 82 posts
Posted 10 April 2017 - 03:01 PM
Its taken a long time to get it to this state that's for sure,  and still a longer way to go :D
Dress code.
Getting the shell back I just had to get the doors and panels hanging off her, here we found some issues like the front head light cones where pinching the bonnet, and the drivers side fender tip was over lapping the door a fair bit, I did spend a fair few hours on this trying to get it as best i could, how ever they will require attention, other then that i was nice to see its overall shape. The nose pinching was helped using one of the rams off the rotisserie.
th_20170331_130748_zpsoiefx6kf.jpg th_20170331_130743_zpsja8hny8z.jpg th_20170405_124038_zpssbzfyjqu.jpg th_20170405_124032_zpsqpygpgkq.jpg
Radiator support
After blasting we found some small holes in the lower corners of the radiator support, easy fix however it came to me I needed to start looking at radiators.. Using a old R33 skyline rad i had laying around i used that as template simply as it has the outlets on the same side and there sized for an RB.
The rad is just a fraction to large to fit between the rails normally, massaging the side of the rad make it slip in perfectly, using this rad filled in the entire front which now makes me wonder if I should enlarge the opening.  Doing this helps as cutting out metal is a lot easier then installing new metal back in.
New rad has been ordered so once that gets here I will finalize where I'm going with this.
th_20170406_093639_zpsrujihto8.jpg th_20170405_142946_zpsexqur8vm.jpg th_20170406_123506_zpsz3o73az0.jpg th_20170406_104341_zpstzlhdr72.jpg
th_20170406_093645_zpsuplo8ikv.jpg th_20170406_093650_zps9ipny1ey.jpg th_20170406_093654_zpsfzomn2ha.jpg
Cowl area
Welded some thick sheet metal to replicate the stiffener panel that was removed prior fixing the rust under the dash. New seam sealer was used to go over the areas that the blasting took out and POR 15 was brushed on everywhere. I probs went overboard with the coatings, thou I wont ever go back into here ever again after welding the top cowl lid back in.
th_20170330_124906_zpscjq0l2za.jpg th_20170330_124909_zpshfey8bja.jpg th_20170330_124904_zpsvr1r2jkq.jpg th_20170330_124900_zpsg560emvg.jpg
th_20170330_140834_zpsc0l1m8mt.jpg th_20170330_140831_zps2veu2lal.jpg th_20170330_140828_zpsd2ziuuy6.jpg th_20170330_140819_zps1xy4u7p7.jpg
Also tagged with one or more of these keywords: 260z, Restoration, Rb26
