Rear Seat Lock/latch For 2+2
11 replies to this topic
#1 Dionysus
Dionysus
  • 299 posts
Posted 16 February 2016 - 12:33 PM
Just wondering if anyone has had an issue with the rear seat latch in a 2+2??
One side of mine doesn't appear to lock in place so before I remove them and take a look it would be nice to get a heads up if someone has gone through the same issue.
If it's stuffed i'm sure I could fix or retrofit something similar.
Thanks
John
#2 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 16 February 2016 - 12:40 PM
Hi John
I also have a problem with mine not locking in.
I do find that if I move both levers at the same time it works fine.
PB
#3 Dionysus
Dionysus
  • 299 posts
Posted 16 February 2016 - 01:06 PM
Hi John
PB
I'll give it a go..
Do you know if they are linked in anyway?
#4 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 16 February 2016 - 02:20 PM
Hi,
Not certain, but I think there is linkage that over time wears and results in the problem.
will check tonight.
PB
#5 Dionysus
Dionysus
  • 299 posts
Posted 23 February 2016 - 09:16 AM
Hi,
will check tonight.
PB
Hmmm
I tried both together and it didn't make a difference..
When I move the lever it feels like there is little movement in latch..
#6 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 23 February 2016 - 10:20 AM
Mine is fiddly and needs to be jiggled in order to lock in.
If you are at the drive day we can have a look at then.
PB
#7 Dionysus
Dionysus
  • 299 posts
Posted 23 February 2016 - 10:30 AM
I saw the event and I'm thinking about it, Windsor is a good hour away to begin with..
I am keen though so we'll see.
#8 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 24 February 2016 - 05:26 PM
The catch for this mechanism has packers under it to get it at the right height to function correctly. Try adding or removing packers, from memory i have a bunch of packers from the 2 X 2+2's i parted out.
#9 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 24 February 2016 - 07:45 PM
Hi Mark
So should they latch automatically when you throw the seat back up ?
Mine doesn't
#10 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 27 February 2016 - 10:19 AM
Hi Mark
Mine doesn't
They should mate yes. It's possible that the hinge mount has come loose and that's why it's not lining up. It's just like a door catch, you might have to spend some time with it to get it right.
#11 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 27 February 2016 - 11:40 AM
Thanks mate - Thought as much, sounds a bit fiddly I will sort it one day.
Not on the top of the priority list, todays flat battery is No.1 priority.
#12 peter t
peter t
    OLD RETIRED Z FART
  • 1,860 posts
Posted 28 February 2016 - 07:28 AM
Right on the money.They gotta line up or they don't work.
