manyu
260Z Rich/rough Running After Filling Up. L28 Carb
Hi guys, been having a few troubles with getting the car to run right ever since I got it.
It's a 2+2 with an L28 that's been converted to carb.
I've noticed only recently (last two fill ups) car runs extremely rich after it's been filled up and it gradually gets better as the tank level keeps dropping. I noticed this due to the fact that the fuel smell inside the cabin when driving gets noticeably higher/unbearable right after filling up.
Does this sound like a faulty fuel pump or a pressure issue? I'd be interested in putting a fuel pressure regulator in with a guage to get a better idea as to what's happening.
What regulators are people using and where do you buy them from?
Cheers.
Share this post
Link to post
Share on other sites
Sounds like its just the fuel vapours venting from the vent hose or filler neck leading to the petrol smell in cabin after filling.
Is your engine running the mechanical fuel pump?
Share this post
Link to post
Don't think it's the vent hose as the fumes are not constant, it's only after you've been flogging it. It's running an electric pump near the tank, not mechanical.
Share this post
Link to post
Have you crawled under and checked the vent hose? I have a similar issue, if I fill the tank totally it leaks slightly at the vent hose.I'll replace it as per recent posts. Enthusiastic driving may be sloshing the fuel around.
Share this post
Link to post
Checked the vent hose, not leaking. The fumes I'm complaining about are exhaust fumes, only happens after hard acceleration when near full tank. Doesn't happen below half tank.
Think my main issue here is that the car is RUNNING noticeably richer on a full tank of petrol, fumes are a secondary issue. Hoping someone can shed light on why it'd only run rich when it's got a full tank of petrol.
Cheers.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
