Administrators gav240z Posted January 7, 2016 Administrators Share Posted January 7, 2016 Hi Guys, I just discovered why my wiper fluid isn't squirting onto the screen, it appears there is a kink in the clear plastic tubing that goes from the motor to the nozzles. For some reason there is a look from 1 side to the rear of the motor and in that loop the plastic is probably a bit short and kinks like a garden hose. Does anyone know where I can order more of this stuff? Once the kind is straightened out the jets work perfect. If I get a chance I'll call Ashley at Moorabbin Auto Spares. Thanks, Quote Link to comment Share on other sites More sharing options...
rb25240z Posted January 7, 2016 Share Posted January 7, 2016 You could probably use air line from an aquarium shop if you cant find anything else. gav240z 1 Quote Link to comment Share on other sites More sharing options...
lightmaster240z Posted January 7, 2016 Share Posted January 7, 2016 Gav try Clarks auto barn Etc or your local pet shop they all should have it Bruce Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted January 7, 2016 Moderators Share Posted January 7, 2016 Gidday Bunnings should have it http://www.bunnings.com.au/search/products?q=Clear%20Hose Cheers PB Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted January 7, 2016 Author Administrators Share Posted January 7, 2016 Thanks guys, i didn't get down to Bunnings in the end. So I stole some excess tubing from some spares I had. This stuff goes hard over time, but doesn't seem to get brittle, just goes from clear to yellow. So for now it works fine but will have to get a roll of it and redo the lot on my S30z's at some point. Quote Link to comment Share on other sites More sharing options...
YosemiteZed Posted January 7, 2016 Share Posted January 7, 2016 Hi Gav I replaced mine with a roll silicon tubing that I picked up on Ebay pretty cheap never goes hard and less kink issues Cheers Phil Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted January 8, 2016 Author Administrators Share Posted January 8, 2016 never goes hard and less kink issues That's what she said. Enzo 1 Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted January 8, 2016 Moderators Share Posted January 8, 2016 Hi Gav I replaced mine with a roll silicon tubing that I picked up on Ebay pretty cheap never goes hard and less kink issues Cheers Phil Hi Phil, Great idea, mine needs replacing and Silicone makes so much sense. I will be hitting Ebay yet again. Cheers PB Quote Link to comment Share on other sites More sharing options...
Andrew_L26 Posted January 8, 2016 Share Posted January 8, 2016 I replaced some of mine with some vinyl tubing and the stuff that I needed to re-shape I just heated up with a lighter and it goes soft, allowing you to move it wherever you please, plus when it cools it stays put! Quote Link to comment Share on other sites More sharing options...
