Wiper Washer Clear Plastic Tubing For Fluid?
8 replies to this topic
#1 gav240z
gav240z
    Administrator
  • 12,958 posts
Posted 07 January 2016 - 11:32 AM
Hi Guys,
I just discovered why my wiper fluid isn't squirting onto the screen, it appears there is a kink in the clear plastic tubing that goes from the motor to the nozzles. For some reason there is a look from 1 side to the rear of the motor and in that loop the plastic is probably a bit short and kinks like a garden hose.
Does anyone know where I can order more of this stuff? Once the kind is straightened out the jets work perfect.
If I get a chance I'll call Ashley at Moorabbin Auto Spares.
Thanks,
#2 rb25240z
rb25240z
  • Donating Members
  • 93 posts
Posted 07 January 2016 - 12:21 PM
You could probably use air line from an aquarium shop if you cant find anything else.
  • gav240z likes this
#3 Lightmaster240z
Lightmaster240z
  • 1,624 posts
Posted 07 January 2016 - 02:12 PM
Gav try Clarks auto barn  Etc  or your local pet shop they all should have it
Bruce
#4 PB260Z
PB260Z
    Peter (PB)
  • 3,308 posts
Posted 07 January 2016 - 02:15 PM
Gidday
Bunnings should have it
http://www.bunnings....ts?q=Clear Hose
PB
#5 gav240z
gav240z
    Administrator
  • 12,958 posts
Posted 07 January 2016 - 09:24 PM
Thanks guys, i didn't get down to Bunnings in the end. So I stole some excess tubing from some spares I had. This stuff goes hard over time, but doesn't seem to get brittle, just goes from clear to yellow. So for now it works fine but will have to get a roll of it and redo the lot on my S30z's at some point.
#6 YosemiteZed
YosemiteZed
  • 100 posts
  • Tagline:Rust never Sleeps
Posted 08 January 2016 - 06:35 AM
Hi Gav
I replaced mine with a roll silicon tubing that I picked up on Ebay pretty cheap
never goes hard and less kink issues
Phil
#7 gav240z
gav240z
    Administrator
  • 12,958 posts
Posted 08 January 2016 - 10:50 AM
That's what she said.
  • Enzo likes this
#8 PB260Z
PB260Z
    Peter (PB)
  • 3,308 posts
Posted 08 January 2016 - 11:56 AM
Hi Gav
Phil
Hi Phil,
Great idea, mine needs replacing and Silicone makes so much sense.
I will be hitting Ebay yet again.
PB
#9 Andrew_L26
Andrew_L26
  • 415 posts
  • Tagline:That Purple Zed
Posted 08 January 2016 - 08:30 PM
I replaced some of mine with some vinyl tubing and the stuff that I needed to re-shape I just heated up with a lighter and it goes soft, allowing you to move it wherever you please, plus when it cools it stays put!
