Removing Tailshaft From Gearbox
3 replies to this topic
#1 RLY240
  • 246 posts
Posted 30 December 2015 - 08:43 PM
This might seem like an odd question but I'm having trouble separating a Tailshaft and gearbox.
The combo is a 5 speed with 3.3 first so probably a 280zx but it's connected to a two piece shaft.
On my rally car the Tailshaft just slips out of the gearbox, the box looks exactly the same as mine but the yoke won't come out. It floats about 5-10mm but stops with a clunk. I've seen the early flange type 240 boxes but this isn't that.
If anyone can suggest a solution that would be great as I don't want to damage it but can't see an obvious solution. Any advice appreciated.
#2 PB260Z
    Peter (PB)
  • 3,314 posts
Posted 30 December 2015 - 09:50 PM
Hi Roger
There is no extra locknut or anything, it is just stuck.
I have seen this once I twice before, usually caused by damage to the output shaft or yoke.
You will need to find a way to apply more force. Disassemble the front the uni and puting a slide hammer across the centreline can work. The challenge is, to much force and you can damage the box
Out of interest what vehicle did the box and shaft come out of ?
Good Luck.
Edited by PB260Z, 30 December 2015 - 09:52 PM.
#3 RLY240
  • 246 posts
Posted 30 December 2015 - 10:41 PM
Guess I need a bigger hammer then...
Box came out of a 240 that was quite a mess, one rear quarter was early (no vent) but it had the toolboxes, gearshift hole had been cut forwards to accomodate this box so it wasn't original to the car, must have been raced at some point as all the lower arms were plated as were the engine mounts and there was a brace joining the rails together.
When I got it the roof had been removed and the chassis number cut out so the original identity is probably lost forever.
#4 Retro Z
Retro Z
  • 1,421 posts
Posted 31 December 2015 - 07:29 AM
Its happened to me a few times, a hammer and a block of wood usually gets it out with a person also pulling on it.
