Used Diff Mounts - Recon
20 replies to this topic
#1 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 27 December 2015 - 09:35 PM
Hi
I recall reading that someone was looking to collect used diff mounts to get reconditined in a job lot.
I have just removed the mount from my car and before I toss it out would enquire does anyone want it ?
PB
#2 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 15 January 2016 - 05:44 PM
Bump
#3 dat2kman
dat2kman
  • 4,061 posts
Posted 19 January 2016 - 10:55 AM
Yes
Me
In order to get mounts ( engine, box r diff) re-rubbered, the guy that can do it mxes up a batch of rubber, he wants 10 items minimum, to make it worth his while,,,,
I have a few odd items, need few more.!
  • gav240z likes this
#4 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 19 January 2016 - 06:13 PM
Hi,
If you PM me your postal details I will send the old one up to you to add to the collection. Rather that than just throw it out.
Whilst I don't need a new one at the moment, would be be happy to help make in the numbers for a group order if needed.
PB
#5 dat2kman
dat2kman
  • 4,061 posts
Posted 19 January 2016 - 10:27 PM
Ta!
#6 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 19 January 2016 - 10:30 PM
What other items are you going to get redone? I have a couple of spare mounts in my collection back in Melbourne I could dig out.
How about engine mounts? Dif? Gearbox?
#7 dat2kman
dat2kman
  • 4,061 posts
Posted 19 January 2016 - 10:41 PM
Yes, yes, yes.
Also will ask the shop if they can do a pour on each side fof a couple of 260 gearbox to floorpan crossmembers, to provide something a bit firmer, but still be flexible.
I''ve had a number of Roadster/Fairlady engine mounts, and S30 engine mounts done, all are still quite good, no sagging, or ripping.
No ruch, but, any old engine, gearbox or diff mounts, no matter how ripped, torn, spongy/gooey they are!
Post them to me, the more I can get done in one hit, the lower the cost.
Its rubber, not polyurethane, and its equivalent hardness to the Nissan Competition supplied rubber mounts
#8 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 19 January 2016 - 10:50 PM
Ok not sure when I'll next be in Melbourne but would be interested in getting these done...
Do you know approx cost of getting this done? Some mounts are still available new and not too expensive from Nissan.
#9 Andrew_L26
Andrew_L26
  • 408 posts
  • Tagline:That Purple Zed
Posted 06 February 2016 - 01:57 PM
I assume we are talking about that rubber front diff strap. If so, put me down for one. I broke mine today...
#10 Andrew_L26
Andrew_L26
  • 408 posts
Posted 06 February 2016 - 02:17 PM
I found this replacement strap online and I'm wondering if it's all I would need to fix my issue?
http://www.thezstore...t_Code=10-2290A
#11 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 06 February 2016 - 04:36 PM
Hi Andrew
No not the strap, we are referring to the bonded rubber mount that goes between the nose of the diff and the cross member.
As an aside, if you have broken the strap, I would say the mount referred above is broken - the strap is intended to "catch" any excessive upward movement that a broken mount would allow.
PB
  • Andrew_L26 likes this
#12 Andrew_L26
Andrew_L26
  • 408 posts
Posted 07 February 2016 - 11:50 AM
Ah ok, I'll look into it
#13 dat2kman
dat2kman
  • 4,061 posts
Posted 07 February 2016 - 02:58 PM
If you have torn the bonded diff mount, please do nt throw it away, instead, consider posting t up to ke, so I can send it ff for new rubber re-bonding.
I replied to your request on bookface re your broken strap, I have a few f these available.
#14 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 07 February 2016 - 06:16 PM
Hi
The mount will usualy look OK, it takes a fair amount of force for the diff to roll up.
You will need to get a lever or similar in there and see what movement is present.
Mine had some areas were the movement had worn the paint off.
PB
Edited by PB260Z, 07 February 2016 - 06:17 PM.
#15 TimDavis
TimDavis
    Newbie
  • Pip
  • 8 posts
Posted 18 April 2016 - 01:12 PM
Hi,
I wondered if anyone could help me, I need a differential rubber mount to suite 8/82 280ZX 2+2 Auto box, I cant find one anywhere,,,, please help
Thanks,
Tim
#16 dat2kman
dat2kman
  • 4,061 posts
Posted 18 April 2016 - 03:25 PM
Dont throw out your old one, if possible, post it to ke, I can get them re-rubbered to as new.
#17 TimDavis
TimDavis
    Newbie
  • Pip
  • 8 posts
Posted 18 April 2016 - 03:37 PM
Hi dat2Kman,
That would be good, do you have an idea on cost and lead time? I can pull it out of the car and post but obviously it renders the care undriveable,
 Tim
#18 dat2kman
dat2kman
  • 4,061 posts
Posted 18 April 2016 - 06:30 PM
PB 260, got your old one, yes, she was torn!
Tim Davis, I am nt able to indicate how long or how much, as the factory that does them fits them in when they are doing the molten rubber compound.
I'd be guessing at around $60 a piece plus postage, and around four weeks?
#19 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 18 April 2016 - 09:30 PM
Thanks for letting me know it arrived, and Yes it was well and truly past its best.
PB
#20 24TZ
24TZ
  • 95 posts
Posted 19 April 2016 - 09:54 AM
Hi,
Thanks,
Tim
I might have a spare, ill check today
