Mx3 Inox On Ball Joints
1 reply to this topic
  • 95 posts
  • Tagline:C210 owner
Posted 21 December 2015 - 12:13 PM
I was replacing my steering balljoints and I put antiseize on the threads and taper. Stupidly, afterwards I went online to check if it was the right to do, and it was not. So I used Inox MX3 to remove the antiseize, will this remove the grease inside the balljoints? should I be concerned? or am I fretting over nothing?
They are sealed for life 555 balljoints.
#2 PB260Z
    Peter (PB)
  • 3,314 posts
Posted 23 December 2015 - 08:36 PM
Hi Mate
Unless you managed to get plenty of Inox inside tne joint I don't think you need to worry.
Regardless, you can't change what has happened so don't stress it, just check them for after a little while on the road.
