'75 260Z Finally Mine
39 replies to this topic
#21 CBR Jeff
CBR Jeff
  • 1,014 posts
  • Tagline:Often lost
Posted 06 April 2016 - 07:31 PM
Looks like a good starting point but don't be too surprised what you find when you start digging. The places you have rust as Gav said are very typical but it's what you cannot see that some times brings little unwanted treasures of the oxidising stuff.
But don't panic it can all be fixed with time patience and some money.
Jeff.
#22 PriceyZed
PriceyZed
  • 47 posts
  • Tagline:Weese the juice!
Posted 15 May 2016 - 08:11 AM
Thanks Jeff, I've been reading your thread. I wish I was a s handy/ confident to tackle the bodywork by myself but I don't have the skills that thrills like you. So unfortunately the panel beater is going to tackle it for me. Met with him the other night and he's keen to sink his teeth into it.
#23 PriceyZed
PriceyZed
  • 47 posts
Posted 15 May 2016 - 08:16 AM
Picked up these bad boys yesterday also. All fairly close numbers and all jetted alike. Not like the 40mm mikuni fiasco that unfolded in one of the for sale posts. They came with linkages and soft mount gaskets also which helps. Might just need some gaskets and one of the chokes is damaged, God knows how...
#24 PriceyZed
PriceyZed
  • 47 posts
Posted 29 May 2016 - 08:41 PM
Made some progress today.
Thanks largely to the help of my brother in law. We managed to remove the engine, transmission came across some rotten coolant housings. Going to have to sort them out. Also started on the interior, removing the dash and seats. Found the original trans tunnel vinyl hiding under some grotty carpet.
Pictures attached
  • oldmates260z likes this
#25 jeff43
jeff43
  • 236 posts
  • Tagline:Go really fast, if something gets in your way turn!
Posted 29 May 2016 - 10:35 PM
And it begins. It looks pretty solid in the engine bay. Hopefully you don't find to many nasty surprises as you go. Good luck and stick with it, you will get there.
Cheers Jeff (J2)
#26 PriceyZed
PriceyZed
  • 47 posts
Posted 30 May 2016 - 09:40 AM
Thanks for the encouragement Jeff.
The more I pull the old girl apart, the better the starting base looks. After pulling out the trans, I saw the full extent of damage to the floor rails. Drivers side is sold however it looks like someone has taken to it with a mash hammer! and the passengers side the same, with a bunch of rust right at the rear of it. Apart from those and the few spots pictured above everything looks pretty tidy. The L28 has been freshened up by the looks of it recently, which might might lead to some money saving in replacing bearings rings etc (depending on how money is looking when I start on the motor) dash looms etc look excellent, apart from some backyard looking radio loom install and a rough relay install which I'm assuming was for lights, also a blown out connector coming from the indicator stalk that had been bypassed, which is all small things that should be easy for a handy sparky such as myself to address ::)
The hard part will be to keep the momentum going when the car goes to the panel beater...
  • mspecr likes this
#27 PriceyZed
PriceyZed
  • 47 posts
Posted 21 June 2016 - 09:54 AM
Just thought I'd throw up some photos summarising the areas that need attention that I've come across after stripping the car.
Apart from the areas in photo's the floor rails will need to be replaced, not necessarily rusted out but beaten to hell so may as well weld in some new ones with thicker sheet steel while I'm at it.
The radiator support is the same, Not rusted but who ever owned this is the past must lived down a rough dirt road cause its beaten to hell as well.
Had a chat with dattocam and he thinks he'll be able to help with most areas that I've outlined which is incredible, can't thank him enough. And getting the floor rails bent up at the local steel supplier in town.
Quick question would be: What gauge of steel would people suggest for the floor rails?
                                         And would it be ok to cut the floor rails after they taper up into the chassis rails and just weld in the straight                                              section?
#28 PB260Z
PB260Z
    Peter (PB)
  • 3,331 posts
Posted 21 June 2016 - 06:17 PM
Hi,
That certainly looks like the normal Z rust issues, but not as bad as many have dealt with.
I spied a HJ/X/Z Wagon in background - yours as well ?
PB
Edited by PB260Z, 21 June 2016 - 06:17 PM.
#29 Groundhog
Groundhog
  • 232 posts
Posted 21 June 2016 - 07:00 PM
There are three layers to the sills in the dogleg area. Take a deep breath and be ready for a rusty mess when you cut away the dogleg. I,d recommend buying complete L&R sills and make the decision on how much of the sill you use when you open it up. The door frame behind the skin will need work too so it is worthwhile seeing if a better door will mean skin only versus frame repair and skin.
Keep the pics coming.
#30 PriceyZed
PriceyZed
  • 47 posts
Posted 21 June 2016 - 09:47 PM
Hi PB. That's my prem (last project) fondly know as Beverly. Completely origional down to the brake lines. Yeah I'm dreading to see what's under the dog legs. Hopefully dattocam can help me out with the shells he has. Should here back in a day or two as to the areas of the car he can help me out with.
#31 PB260Z
PB260Z
    Peter (PB)
  • 3,331 posts
Posted 21 June 2016 - 10:11 PM
Nice, I used to have a Prem got it to tow a boat and it was a great car.
HJ 308, TH400, 10 bolt disc rear end.
That car drank more than I do.
  • aj_ likes this
#32 Lurch ™
Lurch ™
  • 5,725 posts
Posted 21 June 2016 - 11:19 PM
Why do you want to use rusty old donor sections?
New doglegs & sills are available from Tabco/MSA. Floors & rails you can buy new from rare spares.
  • Groundhog likes this
#33 PriceyZed
PriceyZed
  • 47 posts
Posted 23 June 2016 - 05:43 PM
Nice example of a prem. Mine is only a 6 with tri attic but purrs like a kitten so don't want to mess with it to much... For now.
Going to put time and effort into the z then go back and take a look at the drive train on the Ol' prem
Honestly Lurch I haven't seen the new panels from Tabco or MSA I only went with the the panels from dattocam because he advertised and I'm spoiled for choice with his spares. The panels that he can help me with are in pretty good nick and the areas like the fuel filler and floor rails will be fabricated new.
Any suggestions are more than welcome. I'll suss out Tabco and MSA
#34 andyk_79
andyk_79
  • 672 posts
Posted 24 June 2016 - 05:48 PM
My first car was a HZ wagon in that lovely cream / babys*** colour Pete. Brings back memories!!
#35 PB260Z
PB260Z
    Peter (PB)
  • 3,331 posts
Posted 25 June 2016 - 07:30 PM
My first car was a KE20 Corolla, one of many cars I wished I had kept.
#36 PriceyZed
PriceyZed
  • 47 posts
Posted 21 March 2017 - 07:36 PM
So its been ages since my last post and there's been a fare bit of progress.
The car has been completely stripped to a rolling shell and handed to my panel beater for blasting and all hanging panels off.
He talked me into taking off the rear quarters when he saw the dog legs and a small amount of rust on the rear window surrounds.
BEST DECISION EVER... As you can see from the photos, if we hadn't taken them off i would've been looking at bubbles on my nice new
doglegs in 3-5 years. Other areas that came to light were the passenger foot well/ lower battery tray, beneath the slam panel, where the
A-pillar meets the inner guard, and once all the leaves were vacuumed out from under the beaver panel there was a square box that the
blower motor bolts to that was rat s*#t... and just a touch on the firewall.
Also found that the car has been in an accident at some point in its life and a pretty shitty attempt at a repair been done on the drivers side,
floor is a little beet but easily fixed.
So a bit more than i first thought, I'm a little disappointed by how much was found in total but its not the end of the world.
#37 PriceyZed
PriceyZed
  • 47 posts
Posted 21 March 2017 - 07:43 PM
Photos
#38 PriceyZed
PriceyZed
  • 47 posts
Posted 21 March 2017 - 07:49 PM
more photos
  • Rickers likes this
#39 CBR Jeff
CBR Jeff
  • 1,014 posts
Posted 21 March 2017 - 08:11 PM
Pricey I know how you are feeling......unfortunately in most cases rust was an option you got for free.
Looks like the panel beater will sort all of the ratty bits.
Nice progress to date. Nice drop that great northern.
Jeff
Edited by CBR Jeff, 21 March 2017 - 08:12 PM.
#40 PriceyZed
PriceyZed
  • 47 posts
Posted 22 March 2017 - 07:58 AM
Thanks Jeff,
The more I read, the more I see that most Z cars are the same when you start peeling back the layers.
Just thankful that I've got some good support to help where I need it. I'm going to try and do some of
the repairs that no one will see like the inner dog legs etc.
