Suggested Replacement Starter Motor
8 replies to this topic
#1 oldmates260z
oldmates260z
  • 752 posts
Posted 16 October 2015 - 09:06 PM
So what and where would you get a good replacement stater motor?
Some of the newer ones around really spin so much better now and my old girl sits around for a while without being driven and needs all the help it can!
#2 Lurch ™
Lurch ™
  • 5,602 posts
Posted 16 October 2015 - 10:38 PM
RB30 is reduction drive and a direct bolt in.
If you prefer aftermarket: Hi-Torque http://www.caenterpr...2FsbHNlYXJjaA==
  • oldmates260z likes this
#3 oldmates260z
oldmates260z
  • 752 posts
Posted 17 October 2015 - 04:55 AM
Thanks Lurch.
#4 Linton
Linton
  • 517 posts
  • Tagline:1976 260z 2+2 Sunburst 1989 300zx Z32TT 2+2 Black
Posted 17 October 2015 - 07:55 AM
if I remember correctly I used a VL 6 cyl Commodore bolted straight in @ $140
Edited by Linton, 17 October 2015 - 08:00 AM.
#5 oldmates260z
oldmates260z
  • 752 posts
Posted 07 November 2015 - 07:06 AM
Well the RB30 started fitted just fine other than the solenoid being about 180 degrees around away from the block and needing a shorter bolt. Starts really well......
http://www.ebay.com....=STRK:MEBIDX:IT
Edited by oldmates260z, 07 November 2015 - 07:07 AM.
#6 oldmates260z
oldmates260z
  • 752 posts
Posted 15 November 2015 - 09:47 AM
New starter spins really well and is a great starter but......when I take it for a run and try to restart the starter just "clicks" and will not engage. Hit it 4-5 times and it comes good.
The guy I bought it from came back with:
I expect you have voltage drop to the starter solenoid activation terminal... Try bridging direct positive power to the starter solenoid activation terminal, I'm sure it will start everytime. It is a common fault, to overcome it You will need to fit & wire up a starter relay.
Anyone had similar experiences? Thoughts?
Thanks
#7 dat2kman
dat2kman
  • 4,029 posts
Posted 15 November 2015 - 12:40 PM
I dd, on a small block hgh comp 383 cube Chev, did the starter relay rewire thing, never mssed a beat!
But first, check your earths, especially the earth from bdy to engine blck, pull them off, a good clean, bit f wire brush.
Also the pos lead to the starter solenoid, again, check bth ends.
The clicking jst means the solenoid is energising.
Battery in good, charged cond? No power drains causing t to drop in voltage?
#8 oldmates260z
oldmates260z
  • 752 posts
Posted 15 November 2015 - 05:26 PM
Good point Jason....likely just a poor connection somewhere, I rushed the fitment.
#9 Agno
Agno
  • 1,310 posts
Posted 06 December 2015 - 08:15 PM
Thread bump but ANY RB engine starter motor will fit onto an L series engine, the solenoid position is 180 out but no big deal.
I have an R34 RB25 starter motor in mine for reference sake.
