Sign in to follow this
krizza
Trailing Arm Outer Bushing Question
Guys, I have a question regarding the rear suspension and how much articulation it should have.
I have removed the rear arms from my car which are still attached to the uprights, and I have noticed that it feels like the rubber bushes are bonded to the spindle pin. I can get approx 45 degrees movement each way from where the strut sits when in the car if I apply some force to the strut, but it bounces straight back to the original position when I let go of the strut.
I was really hoping not to mess with the outer bushes and leave the spindle pins alone, but I thought I should check what you guys opinions are. Is what I have described normal operation of the trailing arm outer pivot point and can I leave it as is?
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
