R180 4.4 Ratio Lsd, Crown And Pinion. (Or Similar)
28 replies to this topic
#21 Cozza
Cozza
  • 908 posts
  • Tagline:Datsun obsessed
Posted 26 September 2015 - 10:43 PM
The SWR axles are fine but you need R200 half shafts. The 4.4 ratio is a good all rounder
What's the difference between the R180 & R200 half shafts?
I didn't know SWR was making the stub axles but no doubt they will be a top notch product as usual.
Mick
#22 d3c0y
d3c0y
  • 2,847 posts
  • Tagline:Forum Jerk
Posted 27 September 2015 - 11:55 AM
Yep, I have just done one of these conversions. The Subaru R180 diffs come up on eBay periodically from Jap parts importers. The ratio is 4.444 to 1 and they come in either a clutch pack or Torsen style torque sensing LSD. The later are more prevelant but in my opinion less desirable. They come up for around $600. The SWR axles are fine but you need R200 half shafts. The 4.4 ratio is a good all rounder
They aren't all the same ratio. The Suretrak torque sensing diff is the most common, has a 3.9:1 ratio and is the most common. The GDB STi Spec-C also came with a 3.9 but is mechanical type LSD. The later GDG has the Torsen diff and is a 3.5:1 ratio.
  • MyEnquiringMind likes this
#23 locklock
locklock
  • 208 posts
Posted 03 July 2017 - 03:27 AM
What colour pinion gear should i go for if im using r180 4.44?
I only see 4.11, 4.375 and 4.6
#24 d3c0y
d3c0y
  • 2,847 posts
Posted 03 July 2017 - 02:36 PM
Let's see now, which one of those numbers is closest to 4.44...
  • 260DET likes this
#25 Roady
Roady
  • 77 posts
Posted 03 July 2017 - 04:59 PM
Purple is the 4.375 - but things obviously can change with wheel size... from experience, I installed the Subaru 4.44 and used the purple... forgot about rim size. Ended up going to the next one up "orange" Speedo cog to get it right.
#26 Cozza
Cozza
  • 908 posts
Posted 03 July 2017 - 06:16 PM
What size wheel and tyre combo are you going for?
#27 locklock
locklock
  • 208 posts
Posted 03 July 2017 - 08:48 PM
My rear tyre is 205-60-15
#28 Cozza
Cozza
  • 908 posts
Posted 03 July 2017 - 09:59 PM
After a bit of searching, I'm pretty sure the standard tyre is a 175HR14 which is close to a 175/80/14 (I think) and your current tyre is a 205/60/15 you now have approx. 1.2% circumference decrease over standard, bringing your final drive ratio closer to:
4.444' x 1.012 = 4.498 : 1
4.5 sits right between a 4.375 and 4.625 so take your pick. If you pick the 4.375, your speedo will read slightly high and vice versa.
  • locklock likes this
#29 locklock
locklock
  • 208 posts
Posted 03 July 2017 - 10:17 PM
Thanks, think it should be fine.. we uses km/h anyway, doesnt really matter if its off abit. :D
