R180 4.4 Ratio Lsd, Crown And Pinion. (Or Similar)
28 replies to this topic
#1 MyEnquiringMind
MyEnquiringMind
  • 148 posts
  • Tagline:Doin it in a Datsun...
Posted 20 September 2015 - 03:08 PM
Hi Folks,
I am looking for either the GC8 WRX R180 4.4:1 LSD, or a long nose R180 crown and pinion gear set with the 115mm inside diameter (out of a K box) with a similar ratio. I am currently running a 4.1 and looking to go a little shorter ratio, so will consider 4.4 or 4.6 if someone has a diff/crown and pinion available.
Cheers, Jarrod.
#2 d3c0y
d3c0y
  • 2,908 posts
  • Tagline:Forum Jerk
Posted 20 September 2015 - 07:42 PM
That diff ratio is out of a very specific model GC8 - STi version 6 Type RA in case you didnt know.
#3 MyEnquiringMind
MyEnquiringMind
  • 148 posts
Posted 20 September 2015 - 09:14 PM
Thanks d3c0y...
#4 d3c0y
d3c0y
  • 2,908 posts
Posted 21 September 2015 - 09:40 AM
Not sure if that is a sarcastic thanks or not. I just know because this is the diff i have in my car. Don't forget to get a new speedo pinion.
#5 MyEnquiringMind
MyEnquiringMind
  • 148 posts
Posted 21 September 2015 - 03:35 PM
not a sarcastic thanks buddy, I am genuinely keen to find one of these and appreciate the response... and also the comment Re: change of speedo pinion, I have previously tried Courtesy Nissan in the states, but no luck... do you know where I could find a speedo pinion d3c0y?
#6 gav240z
gav240z
    Administrator
  • 12,653 posts
Posted 21 September 2015 - 03:51 PM
I seem to recall a discussions on this conversion. Is there a thread that details what's involved to make it work in an S30z?
#7 d3c0y
d3c0y
  • 2,908 posts
Posted 21 September 2015 - 11:04 PM
I got mine from Chesapeake Nissan. They have a great list of parts on eBay and you can just message them direct with specific requests. It's the the purple one fwiw.
#8 MyEnquiringMind
MyEnquiringMind
  • 148 posts
Posted 22 September 2015 - 03:02 PM
Thanks D3c0y...
#9 d3c0y
d3c0y
  • 2,908 posts
Posted 23 September 2015 - 09:32 PM
No probs
#10 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 25 September 2015 - 02:51 PM
In the USA:
http://www.ebay.com/...f25762c&vxp=mtr
Or if you prefer the UK:
http://www.ebay.com/...4be11b2&vxp=mtr
I would consider your 4.1 LSD if you choose to sell it.
#11 d3c0y
d3c0y
  • 2,908 posts
Posted 25 September 2015 - 05:13 PM
Buying them in Japan is waayyyyyy cheaper.
#12 Cozza
Cozza
  • 967 posts
  • Tagline:Datsun obsessed
Posted 25 September 2015 - 08:23 PM
G'day Jarrod
Do you plan on running the beta Motorsport side axles, which suit the Subi diff?
I have a 4.6:1 ratio diff which I got from the front end of a 720 4x4. It is a "K" housing and needed a slight amount of massaging inside the case to fit a Subi LSD centre. Also had to make up some shims to cater for 11mm bolts in 12mm holes.
Might be a cheaper option?
Gav, here's a thread on the Subi diff although mostly discussing cv options.
http://www.viczcar.c...-lsd-into-240z/
Mick
#13 MyEnquiringMind
MyEnquiringMind
  • 148 posts
Posted 26 September 2015 - 12:00 AM
Hi Mick,
yeah I already have the axels, I picked them up from a bloke David from Gympie.
http://www.gumtree.c...haft/1084823021
I have already got a 4.8 Datsun diff (Quaife LSD) in the shed at home, but in the early stages of this build, I was going to try and find something a bit more streetable, i.e. 4.1 or 4.4 and see what that was like...
Thanks for taking the time to reply...
Cheers, J
P.S. after pulling the rear cover off, I am now aware that the R180 in situ is in fact a 3.5 and not a 3.9 or 4.1 as expected... so i'll be happy to take a 4.1 if anyone has one spare... (oops...)
Edited by MyEnquiringMind, 26 September 2015 - 04:30 AM.
#14 MyEnquiringMind
MyEnquiringMind
  • 148 posts
Posted 26 September 2015 - 04:38 AM
In the USA:
Thanks Roberto, unfortunately my current diff is niether LSD, nor 4.1... (read above).. nor am I feeling that rich... looks like I might have to get Craig Ford to go on the hunt for me...
#15 Cozza
Cozza
  • 967 posts
Posted 26 September 2015 - 08:44 AM
Cool
I have a 3.9 as well as the 4.6. The 3.9 is a good street application (especially if you do significant highway driving) and the 4.6 is great for the shorter tracks like Wakefield or the Amaroo circuit at SMSP.
I imagine the 4.1 would be a good compromise and make your car a lot more spritely over the 3.5.
I'm sure the rally boys would be interested in the 4.8 LSD.
Good luck with it
Mick
#16 dat2kman
dat2kman
  • 4,061 posts
Posted 26 September 2015 - 08:53 AM
4.6 and 4.8's are common, in utes.
The Nissan R180 in 4.375 was a Nsmo Competition part,,and rather rare, even 30 years ago.
The higher number of pinion teeth give it better reliability compared to 4.6-5.1's
Yes, easier to source a Subaru version, ex Japan, then change the stubs. Check with SWM he was getting a better quality stub made, as, in severe use ( rally/circuit) SWM found the Beta stubs were failing.
#17 Riceburner
Riceburner
  • 3,261 posts
Posted 26 September 2015 - 08:54 AM
I was looking at those axels too, they seem to be well made!
Yeah Jason, there's been a few issues with those billet 'wolf creek/beta axels recently on Hybridz.
If you can spare the coin, get the gear set isotropic finished. I did mine and it's the most quiet diff I've ever heard.
Edited by Gareth. J., 26 September 2015 - 08:57 AM.
#18 Riceburner
Riceburner
  • 3,261 posts
Posted 26 September 2015 - 08:59 AM
How strong are the Subaru R160 LSD's? For a road car it could be ok...
On Hybridz there's guys running LS1's with Subi R180's and they break the billet axels not the diff.
#19 dat2kman
dat2kman
  • 4,061 posts
Posted 26 September 2015 - 10:11 AM
Yep, the "billet" axles aint as good as original factory ones,,,,,
#20 Mike260LW
Mike260LW
  • 126 posts
Posted 26 September 2015 - 11:03 AM
Yep, I have just done one of these conversions. The Subaru R180 diffs come up on eBay periodically from Jap parts importers. The ratio is 4.444 to 1 and they come in either a clutch pack or Torsen style torque sensing LSD. The later are more prevelant but in my opinion less desirable. They come up for around $600. The SWR axles are fine but you need R200 half shafts. The 4.4 ratio is a good all rounder
