Can't Get The 240Z Reclining Seat Mech. To Work
seat
13 replies to this topic
#1 aircobra
aircobra
  • 691 posts
Posted 23 August 2015 - 09:43 AM
just got all my parts back from the platers and put the seat mech. together, after having a look at a couple of phots, but something's wrong
see this photo
1. the tilt work perfectly - move the lever , the latch moves down, the spring pushes the seat forward. gold
2. however, the teeth on the seat frame dont; engage any of the latches and so not only is there no tilt adjustment in the seat ( why have the teeth?) , but the seat back just moves backwards against the spring. so if i seat in on the seat and lean back, there's nothing to stop it. all the components look original when i disassembled them
have i put it together wrong?
https://www.flickr.c...eposted-public/
#2 zeds4ever
zeds4ever
  • 868 posts
  • Tagline:Old Member
Posted 23 August 2015 - 11:39 AM
G'day mate, looking at the pic you posted you are missing the small plate that locks into the seat rail section to keep it in the desired position. I tried to download a pic for you but for some reason can't get it to work. If you send me your email address i'll forward one to you direct.
                                             Regards: Alan.
#3 zeds4ever
zeds4ever
  • 868 posts
Posted 23 August 2015 - 12:15 PM
Gav ,I'm having problems with downloading pic.
                                    Regards:Alan.
#4 aircobra
aircobra
  • 691 posts
Posted 23 August 2015 - 01:02 PM
i used this to compare
http://www.ebay.com/...M-/111726517725
also, i don't suppose you know where the "notify me of replies" feature is, do you?
#5 aircobra
aircobra
  • 691 posts
Posted 23 August 2015 - 01:10 PM
you can just see it protruding in this photo here
http://www.classiczc...50824743202.jpg
i think its off a 280, though
#6 GongZ
GongZ
  • 844 posts
  • Tagline:Watanabe wannabe
Posted 23 August 2015 - 02:55 PM
It is now called "Follow this topic" and the button is at the top right of the page.
                                    Regards:Alan.
It should be OK now Alan
Edited by GongZ, 23 August 2015 - 03:05 PM.
#7 zeds4ever
zeds4ever
  • 868 posts
Posted 23 August 2015 - 03:53 PM
G'day mate , here is the pic finally.
Many thanks Gav, your a whiz mate. What would we do without you .!!!
                       Regards: Alan.IMG_0928.JPG
#8 aircobra
aircobra
  • 691 posts
Posted 23 August 2015 - 04:05 PM
many thanks
totally crazy, but it was definitely not there whne I took it all apart !!!
next question is : who will sell me a pair??
#9 zeds4ever
zeds4ever
  • 868 posts
Posted 23 August 2015 - 04:17 PM
Just make sure you get a set from the earlier model as they have a finer teeth set up compared to the 2+2 model.
                                                Regards:Alan.
#10 gav240z
gav240z
    Administrator
  • 12,643 posts
Posted 23 August 2015 - 08:40 PM
Probably a lot more work done on your cars! :)
#11 aircobra
aircobra
  • 691 posts
Posted 23 August 2015 - 09:46 PM
actually, just noticed that my lever is mounted upside down and is a different shape to yours?
#12 aircobra
aircobra
  • 691 posts
Posted 24 August 2015 - 09:50 PM
http://www.ebay.com/...5d7bc35&vxp=mtr
you can just make it out in this photo
#13 zeds4ever
zeds4ever
  • 868 posts
Posted 07 February 2016 - 09:02 PM
You are correct , the pic I posted is of a 2+2 model . That's why I mentioned to make sure you get the 240Z model as the teeth on the insertion plate is finer. The 2+2 wont interlock into the 240Z type.
                                                    Regards : Alan.
#14 aircobra
aircobra
  • 691 posts
Posted 07 February 2016 - 09:05 PM
all fixed, i got the cams from a wrecker and it all works like a charm
can't believe they were missing from both the seats
must be hard to get part
