R200 diff install, tail shaft length
4 replies to this topic
#1 twoforty z
twoforty z
  • 115 posts
Posted 15 August 2015 - 03:16 PM
Hi all,
I'm installing an R200 LSD into my April 1971 240z with an RB20det and R32 gearbox. I've got all the pieces I need: 260z diff crossmember and new mount, half shafts, stub axles, curved rear transverse link, 260z companion flange etc.
Last piece of the puzzle is my tail shaft, which was custom made when the RB20 was installed. How do I measure how long it needs to be? and can I work it out now before the diff is in or just play it safe and measure it up once the diff is installed?
#2 KatoKid
KatoKid
  • 1,663 posts
Posted 15 August 2015 - 09:08 PM
Play it safe and wait until you can measure in the car. Find who you want to do the job and then ask them what measurements they want......every driveshaft shop is different.
#3 dat2kman
dat2kman
  • 4,031 posts
Posted 15 August 2015 - 09:23 PM
Nope.
You need to fit everything up, then do a check measure.
I have a members car here, that had pretty mch same setup, a mechanic bloke had rdered a new tailshaft, based on guesstimates.
Turned out shaft, once bolted, was only engaging splines into gearbox by 10-15mand was rather wobbly!
#4 twoforty z
twoforty z
  • 115 posts
Posted 15 August 2015 - 11:42 PM
Yeah thats what i had assumed, guess impatient me was hoping otherwise.
Also is it possible to change over the diff strap brackets to the later 260z items so the strap lines up?
Thanks guys
#5 Z
Z
  • Donating Members
  • 416 posts
Posted 16 August 2015 - 10:11 AM
As Jase stated it is a lot better to fit everything in the car and be sure the measurements are correct for yor car and parts. God only knows I've had enough re-work to agree  :o
