s12+8 rebuild kits
28 replies to this topic
#21 dat2kman
dat2kman
  • 4,061 posts
Posted 11 August 2015 - 03:48 PM
Take the calipers down to Niel Barker at Custom Brakes & Automotive, Ellen St Moorooka.
Ask him if he can sort you out.
If not, ask him for Phil Topfer's business and address ( Salisbury somewhere?)
Phill will definately be able to supply everything.
( if I was at home atm, i'd post up Phils details from his business card, but not home for 2 more weeks!)
Or can you wait a bit?
#22 74zzz
74zzz
  • 532 posts
Posted 11 August 2015 - 03:59 PM
This is him i think Jason just googled his name...... http://commercialbra...om.au/about-us/
#23 74zzz
74zzz
  • 532 posts
Posted 12 August 2015 - 01:07 PM
Soooo......taking calipers off hasnt been the half hour process i thought it was gonna be.......every copper nut on my car has been stripped round.........not sure how previous owner managed to tighten them......before i strip the last remaining sides of my brake line nuts has anyone got any tricks besides some innox light tapping and patience :)
#24 hmd
hmd
  • 300 posts
Posted 12 August 2015 - 01:19 PM
You need to use one of these spanner
http://www.totaltool...2/#.Vcq7IvmqpBc
Designed for soft metal flare nuts. Wraparound design prevents disortion of soft metal corners. Provides additional torque without spreading
#25 74zzz
74zzz
  • 532 posts
Posted 12 August 2015 - 03:00 PM
its a little to late for a spanner.........they are too far gone
#26 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 12 August 2015 - 06:37 PM
If they are indeed well and truly stuffed, maybe try a set of good condition vice grips.
Just be sure to lock them on VERY tight then be as gentle as possible.
Good luck
#27 74zzz
74zzz
  • 532 posts
Posted 12 August 2015 - 09:46 PM
Yep ended up resorting to vice grips and will get the lines remade. Seals and pistons are rooted on both sides.  Not a major drama....but something else that needs doing before the good stuff can start ie new triples and a forged bottom end.
#28 74zzz
74zzz
  • 532 posts
Posted 13 August 2015 - 12:27 PM
Cheers Jason dropping them into Phil for a very reasonable price!
#29 dat2kman
dat2kman
  • 4,061 posts
Posted 13 August 2015 - 08:55 PM
Yes, Phil Topfer shop!
For future, if rounding flare nuts is a possibility, and you can, or should be able to "feel" a flare nut spanner starting to slip, STOP, and get down to a decent plumbers supply, or tool supply, and grab yourself a "Mini Stilsons" wrench, they are about 5-6" long, the jaws are designed to increase tightness as you increase force on the handle.
A sharpish hit with your palm should release the flare nut.
And if you are a tightarse cheapskate, do the buggered ones back up with the mini Stilsons!!!
