Clutch sizes query
7 replies to this topic
#1 aircobra
aircobra
  • 731 posts
Posted 14 July 2015 - 12:33 AM
Not sure if I am posting in the right section, but trying to get a replacement pressure plate and have searched the forums
throwout sleeve bearing -57
clutch plate - 55
flywheel clutch face - 229 (should be 225)
it doesn't make sense, the tall plate goes with the short bearing?
#2 d3c0y
d3c0y
  • 2,948 posts
  • Tagline:Forum Jerk
Posted 14 July 2015 - 09:43 AM
I don't think people understand what you are saying. I sure don't.
#3 Retro Z
Retro Z
  • 1,416 posts
Posted 14 July 2015 - 09:56 AM
There are 2 sizes of clutches 225mm or 240mm.
And there is like 6 different heights of throwout collars available.
Yes a tall pressure plate goes with a short collar, or vice-versa.
You need 92mm 'overall height' of the pressure plate+collar/bearing. Or mesaure from the flywheel surface to the surface the clutch forks ride on the collar (ears).
#4 aircobra
aircobra
  • 731 posts
Posted 14 July 2015 - 12:27 PM
looks like some people do, but i should have been clearer
these are measurements in mm of the various clutch components
1. clutch surface diameter measured at the flywheel
2. other measured laying the component flat on the workbench and measuring the overall height. in the case of the plate, its to the "fingers", in the case of the "sleeve", its to the top of the bearing
#5 Lurch ™
Lurch ™
  • 5,689 posts
Posted 14 July 2015 - 02:39 PM
clutch plate - 55
Posted Image
#6 aircobra
aircobra
  • 731 posts
Posted 14 July 2015 - 04:07 PM
ok i ll stack them up tonite and see if i get to 92
#7 aircobra
aircobra
  • 731 posts
Posted 15 July 2015 - 07:21 PM
here's the phots
9.9 cm from base to top of the ears
https://www.flickr.c...eposted-public/
#8 Retro Z
Retro Z
  • 1,416 posts
Posted 17 July 2015 - 08:16 AM
That pressure plate is too tall,i can tell just by looking at it.
I have a new exedy clutch and collar i can sell you that should suit. If you're interested ill measure tomorrow.
