Sign in to follow this
Stivva
coilovers for the lazy bloke.
Can somebody point me in the direction of some adjustable coilovers that I can bolt in. And if thats not a possibility, show me what to buy, piece by piece for the four corners and tell me who can do the weld up and installation. I would rather give someone the car and pay them to collect the parts and install them.
Share this post
Link to post
Share on other sites
I fitted an almost bolt on kit for a 240Z to an Sr20DET powered 200B. I'll find it and tag you if i can.
Mark
Share this post
Link to post
Acrow builders house props, two nuts, weld spring perch to one of the nuts.
Machine ID so it just slips over strut tube. Couple spot welds top and bottom.
The nuts are able to be thinned a bit, so that they have smooth flat faces.
Bit rough, but somewhat low cost!
Share this post
Link to post
Not particularly  looking for low cost, just for someone to do the work for me. I mean, i love to save coin, but i dont want a ghetto install.
Share this post
Link to post
Technotoy tuning do a complete bolt in kit
Share this post
Link to post
Just send your struts to MCA and they send you back coilovers, doesnt get much easier.
Share this post
Link to post
Only problem with this MCA bloke is that the 07 number indicates he is interstate, so I can't drop the car off and pick it up complete.
http://www.ebay.com.au/itm/D2-Racing-RS-Coilovers-36-Way-Adjustable-70-78-240Z-260Z-280Z-Suspension-Kit-/221793747215?hash=item33a3f0010
Can I buy the above and pay someone to weld on the required parts, would that be all that I would need? Or a similar kit?
Share this post
Link to post
So happy to get crap suspension from the states and get someone to weld it in... But taking your car to a workshop and saying remove my suspension and send it to mca is to hard?
Share this post
Link to post
Yes, too hard. I don't know a mechanics that would be happy to leave the car jacked up on a hoist for roughly three weeks while the struts were out and interstate.
I also live an hour away from my car and have done so now for over 12 months. I don't have a garage, a carport or a shed at my house to be able to pull the struts out. I haven't even been able to even bring the zed to my house since i moved. So yes, this is actually all to hard for me. I need to be able to drop my car somewhere and be able to pick it up completed.
Share this post
Link to post
Will take on board that the link to coilovers are no good, so i shall not purchase them. Thanks
Share this post
Link to post
That is a service that is hard to find!
I am doing exactly this for a fellow Qld member of this forum.
Share this post
Link to post
Well, if somebody wants to donate some time and a excavator to dig me out an area for a concrete slab I could build a carport lol
Share this post
Link to post
Another option if I could borrow a set of struts and send those to get converted into coilovers by MCA then upon completion of the build I could give the lender my old struts...
Share this post
Link to post
Fulcrum? had to send mine to Sydney for the fronts but were done within the week. That was for the bottoms to be welded onto the sleeves. Get some cheap eBay ones and send them away for them to rebuild. Leave your old ones in while you wait.
Share this post
Link to post
Just buy some struts and send them away to get done, then drop the car off to someone locally for the changeover, I think rob at the z factory had some struts for sale.
Share this post
Link to post
I agree with Mossy, but even when you get a new set of coilovers, you are going to have to set all the heights and swap the brakes over etc. That in my experience is a pretty big job in itself. As with other "bolt in" options for the zed it still can take a bit of time to get it all sorted.
Share this post
Link to post
Yep find some struts and send them to Josh at MCA and get the job done once and done properly. Then swap them over or get a shop to swap them over and on sell yours.
Jeff
Share this post
Link to post
Kanden suspension in Japan make a bolt in kit.
You will need to press in your stub axles and get new rear bearings.
But they are as bolt in as you can get and are very high quality.
You can contact Nori San through the bmd ( Barramundi design wheels )
Face book page.
He speak very good English.
Cheers Doug
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
