Simestime Posted June 27, 2015 Share Posted June 27, 2015 Has anyone made an air box for the triplets?Two reasons i want to make one is for the cold air with a pod in the nose and two for some where for the crankcase and head ventilation to go for a roady(via a catch can).I have the 63mm weber ram tubes so it should get 50mm?? or so in front before hitting the side in the bay.The catch can i have has 14mm?? pipes in and out,is it ok to reduce the size down this much if both top and bottom hoses were going in? Quote Link to comment Share on other sites More sharing options...
GongZ Posted June 27, 2015 Share Posted June 27, 2015 Have a look at these posts/threads; The most recent topic is this one; http://www.viczcar.com/forum/index.php?topic=15431.0 This topic discusses cold air boxes including some retail versions that are available from manufacturers such as TWM (and their shortcomings). It also shows photos of 260Coupe's (Alan's) air box, which I believe is from a Prince Skyline GT-B (modified to fit); http://www.viczcar.com/forum/index.php/topic,9061.15.html A post featuring Les Brennan's transparent perspex set up; http://www.viczcar.com/forum/index.php?topic=10246.0 Scoota G's cold air box made from a rocker cover; http://www.viczcar.com/forum/index.php/topic,3183.0.html Quote Link to comment Share on other sites More sharing options...
RAP260 Posted June 28, 2015 Share Posted June 28, 2015 Hey simestime , I understand you're thought's regarding a roadworthy setup for triples. If I had kept mine , I was looking at something like this. http://www.racetep.com/ztripdcoe.html Quote Link to comment Share on other sites More sharing options...
