15/16 Brake master cylinder.
7 replies to this topic
#1 mouse240z
mouse240z
  • 38 posts
Posted 10 June 2015 - 07:25 PM
Hi All,
Does anyone know where I could purchase a 15/16 brake master cylinder for a 240z in Melbourne?
I purchased a Willwood 1" and it is way to hard for the 4 spot caliper setup I,m running.
Cheers Kevin.
#2 Roady
Roady
  • 88 posts
Posted 12 June 2015 - 05:25 AM
Hi Kevin,
I'm sure there will be plenty of ideas out there but when I upgraded to larger calipers I went with a Nissan Patrol 1" bore. Still all mounts straight up to the original set up and easy to buy brand new from a brake place.
I can't remember price but it wasn't outrageous.  I can find you a part number if you are interested or someone else might have it handy
#3 hmd
hmd
  • 310 posts
Posted 12 June 2015 - 08:02 AM
http://www.viczcar.c...hp?topic=8317.0
JB1361 is the part number, google it there's plenty online stores that sell it.
#4 Lurch ™
Lurch ™
  • 5,684 posts
Posted 12 June 2015 - 08:03 AM
Go back to a 7/8 M/C & re-adjust your pushrod, Kev...
#5 mouse240z
mouse240z
  • 38 posts
Posted 12 June 2015 - 09:00 PM
Lurch,
I was kind of thinking along those lines myself to install a 7/8''just to see how the pedal feel would be.
A lot of other people have posted so called good results from 15/16'' master cylinders with willwood 4 spots. I am sceptical that a 1/16 reduction from 1'' to 15/16 would give me the pedal feel I'm after.
#6 Lurch ™
Lurch ™
  • 5,684 posts
Posted 12 June 2015 - 09:22 PM
PM your braking details - pad size cross-section, pistons dia & how many there are, effective disc size.
I'll run the calcs early next week & give you the results for what size MC you need.
#7 dat2kman
dat2kman
  • 4,079 posts
Posted 12 June 2015 - 09:26 PM
Do a calculation of square mm area of stock calipers (4 pistons) vs the new Wilwoods, (8 pistons)
Then calculate square mm area of stock m/c, vs 15/16 vs 1"
Fr a gven dstance of travel each m/c displaces a given qty of fluid, then divide that into the calipers ( total sq mm)
That will give an indication of what combo is closer to stock.
Bear in mnd, the bigger the m/c, the greater the pedal effort to displace.
#8 mouse240z
mouse240z
  • 38 posts
Posted 12 June 2015 - 09:48 PM
Thanks for everyones input so far. Lurch I will PM you figures I have on hand.
