Complete bolts kits - any sources for non-stainless
29 replies to this topic
#21 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 30 May 2015 - 04:06 PM
If you want original style fasteners etc.. just let me know which ones you can't find. I'm pretty sure if you look in the right places you can find a lot of the original style fasteners.
#22 aircobra
aircobra
  • 692 posts
Posted 02 June 2015 - 11:37 PM
do you mean you know where to get a set, do you have the actual bolt sizes or do you have a set?
#23 Azman1984
Azman1984
  • 97 posts
  • Tagline:Z lover
Posted 03 June 2015 - 02:11 PM
Hey guys on these faster kits, I'm assuming most don't like using these for their builds to keep with originality?
Also what do you think of the pricing of them?
#24 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 03 June 2015 - 02:17 PM
I mean if there is a particular fastener you want and style I may be able to tell you where you can source it if Nissan says it's NLA. Unfortunately I don't know of any kit that will cover an entire car that can be purchased.
My impression of the kits is that they will get you 90% there and are not 'original' per say. The original Nissan ones often had numbers on top that indicate their strength etc..
I think if you were to price up bolts on their own and order them separately the kits would look like good value.
I'm probably going to retain what I can of the originals I have (Depending on their application, obviously engine bolts should be changed) and will try and get mine zinc/chromate plated to their original sheen.
#25 Azman1984
Azman1984
  • 97 posts
  • Tagline:Z lover
Posted 03 June 2015 - 03:06 PM
Thanks Gav!
I'm not too worried with the originality of the smaller things like nuts and bolts on my 2+2 build. Given that quite a lot of my bolts seem to be mismatched and or rusted to the point of breaking I might just keep these kid in the back of my mind.
#26 nat0_240_chevZ
nat0_240_chevZ
  • 842 posts
Posted 03 June 2015 - 10:03 PM
careful replating too.
can cause them to become brittle!!!, even with the pro's, unless they explicitly 'degass' them.
look up 'hydrogen embrittlement zinc plating' on Dr-google!!!!
But again, for $3/kg for plating it can be done cheaply with good results!!! (+ GST of course!!!) but I aint letting out any secrets as to where!!! :)
nat0
#27 Zedman240®
Zedman240®
  • 5,198 posts
Posted 04 June 2015 - 05:11 PM
A good place or shop to get sems assemblies as they are called (bolts / screws with washers that cant be removed) is from a company called "Bolted" his name is Eddie. Nice guy that sells kits of different sized from M5 I think to M8 which the zed uses. Not sure if he has the metric fine in M8 so its best to ask. Heads may not be 100% as they dont have the numbers stamped like a 4 or 7 but look great. If you want a good plater theres one in Moorabbin that is ultra quick and minimum charge is approx $50 for a small bucket. Avin Plating is the place and he does plating for some of the automotive companies.
  • gav240z likes this
#28 aircobra
aircobra
  • 692 posts
Posted 05 June 2015 - 12:27 AM
why not share a secret if its a good one?
#29 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 10 February 2017 - 12:38 PM
And thus the threads were merged on bolt kits for S30Z's.
Just came across these..
http://www.ebay.com....tm/222136671259
ebay seller: http://www.ebay.com....=p2047675.l2559
Only problem is it appears to be too good value for money!
Price:AU $92.00 (based in Sydney too!)
#30 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 07 May 2017 - 11:55 AM
So anyone bought this kit before?
http://www.ebay.com....pe/222136671259
http://stores.ebay.c...suppliesonline/
