Front calipers piston removal - how and who?
6 replies to this topic
#1 aircobra
aircobra
  • 709 posts
Posted 12 April 2015 - 10:16 PM
in the progress of rebuilding my calipers and have split them apart, but can't remove the pistons
i just want to get them out to have a look at the condition of the bores to see if they're worth rebuilding
does anyone know how to get them out? compressed air does not do the trick for me
or maybe recommend a good place in south that can do it for me
#2 Linton
Linton
  • 528 posts
  • Tagline:1976 260z 2+2 Sunburst 1989 300zx Z32TT 2+2 Black
Posted 13 April 2015 - 08:13 AM
if air wont push them out you might have to put them back together and hook up, put a piece of wood between them and pump the pedal, if they are not seized put back together and us air again good luck! and watch your fingers
#3 smugley
smugley
  • 146 posts
  • Tagline:71 240z tarmc rally car
Posted 13 April 2015 - 12:25 PM
Use a grease gun !
The thread is the same as the caliper and is much safer than using compressed air .
Its a bit messy but it's what the pro's use .
Cheers Doug
#4 gav240z
gav240z
    Administrator
  • 12,744 posts
Posted 13 April 2015 - 01:48 PM
Wear eye protection also, brake fluid in eyes not good.
#5 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 13 April 2015 - 02:09 PM
WHS Gav on the scene!
we want to see a hard hat,safety vest and a harness if standing up...
#6 gav240z
gav240z
    Administrator
  • 12,744 posts
Posted 13 April 2015 - 02:21 PM
I like my eyes my mother gave them to me.
https://youtu.be/0nFxZipsiOM?t=49m38s
#7 aircobra
aircobra
  • 709 posts
Posted 15 April 2015 - 07:44 PM
all sorted
better brakes in breaside removed them for me, they have a hydraulic pump at the shop
damage is 4x pistons @19 each, 2x seal kits @14 each and 2 bleed nipples
all i need to work out if to sandblast the caliper or just degrease
the rotors are 12mm and rusty, so I figure that if I get them skimmed, I loose .5 and I will be within .5 limit.
i think 11mm is min thickness
any sources for cheap rotors?
