260z electric fuel pump replacement?
4 replies to this topic
#1 tin
tin
  • 62 posts
  • Tagline:260z
Posted 06 April 2015 - 06:21 PM
can anyone suggest a replacement fuel pump that i can buy?
ive done a quick google and all everyone talked about is if the cars came with either or both mechanical fuel pumps and just gave me a headache
so all i really want to know is what replacments do people usually buy as i'd like to replace mine for peace of mind.
cheers
#2 Riceburner
Riceburner
  • 3,266 posts
Posted 06 April 2015 - 07:25 PM
This Pierburg is what I have run for many many years without any issues at all. Running via a relay for stable power supply, with a filter before the pump inlet, I get 2.9psi at the carbs. I've ran it with original SU's, triple dellorto's, bike carbs and the FCR's. It's very quiet too.
Probably available for cheaper if you shop around, I paid $99 IIRC.
https://www.efihardw...40hp-Rollercell
#3 Agno
Agno
  • 1,334 posts
Posted 07 April 2015 - 07:39 PM
I paid $140 for the Pierburg 2 years ago and currently run it on my triples setup with a Malpassi FPR set at 3psi. The combination is great... just run a relay to the fuel pump otherwise the factory wiring delivers variable voltage depending on the electrical load of the car.
#4 tin
tin
  • 62 posts
  • Tagline:260z
Posted 08 April 2015 - 12:22 AM
thanks for the replies guys,
will definitely run a relay, being 40year old loom the voltage drop can be huge.
ive actually gone with a carter pump and holley reg , head great things and for the price wasnt too bad.
#5 boost
boost
  • 69 posts
Posted 13 April 2015 - 12:47 PM
How do you know if your car is running both or just a single mechanical pump ?
Where is the electronic pump located?
edit. Never mind, found out the 74 260z have mechanical pump only.
