240z half shaft compatibility
3 replies to this topic
#1 Cozza
Cozza
  • 904 posts
  • Tagline:Datsun obsessed
Posted 31 March 2015 - 09:42 PM
G'day all
Just wondering if 1600 / 180B / 240K half shafts are compatible with 240z?
Thanks in advance
Mick
#2 dat2kman
dat2kman
  • 4,029 posts
Posted 01 April 2015 - 08:36 AM
Yes.
And the ones without the grease nipple in the uni joint cross are stronger, as the thread for the grease nipples are a stress riser.
Be aware, some half shafts utilise a bolt in type inner, in place of flange/flange at each end.
#3 gilltech
gilltech
  • Donating Members
  • 1,077 posts
Posted 01 April 2015 - 04:33 PM
Probably. But you need to compare before buying anything.
I'm pretty sure the 1600s & 180Bs & 200Bs used an R160 diff IIRC?
The 240K & 240Z both used the R180. I don't know if the ratios were different, knowing Nissan... probably.
Then the 260Z manual cars used an R200, the auto cars an R180.
Some diffs have flange/flange, others have a flange at wheel end & a single centre-bolt-on sleeve at the diff end as dat2Kman says.
#4 Cozza
Cozza
  • 904 posts
Posted 01 April 2015 - 05:54 PM
Thanks for the confirmation Fellas
I have a bunch from some old projects but can't remember what they came from as I've had a couple 1600 a couple 180B's and wrecked a 240K.
I will replace the unis in a spare set then do a diff and half shaft swap once it's all ready to go, the plan is not to have it off the road for long.
I just wasn't sure if they were the same length but now you've answered that.
Thanks again.
Mick
