Brakes upgrades ideas on a 260Z
92 replies to this topic
#21 lambs
lambs
  • 131 posts
Posted 13 April 2006 - 10:45 AM
How'd you go about fitting the BMW calipers? And where'd you collect them for $60? It seems to be an interesting alternative.
Sorry, I missed this. The BMW calipers bolt straight to Z caliper mounts, but require a small amount of shimming to get the offset correct for the discs. Because they use the Eurpoean dual independant brake cct they also either have to be drilled internally to 'join' the piston cylinders or an adaptor is used to connect both inlet ports to the single Z brake line. I went with the drilling option.
$60 was from a BMW wrecker.
#22 lambs
lambs
  • 131 posts
Posted 13 April 2006 - 10:47 AM
Rear Disk Conversion Kit Group Buy.
Looks more or less identical to the R31 type.
#23 zedevan
zedevan
  • 1,346 posts
Posted 13 April 2006 - 12:11 PM
my gf flat spotted both her rear brakes in an accident (still managed to stop in time surprisingly...but person behind went into the back of her) so i put my spare on her 87 cressida which has the same stud pattern and offset, so i was wondering if anyones ever done a rear disc conversion from one of them...
what diameter rims do you need to clear those ones you're buying sulio?
#24 Toecutter
Toecutter
  • 2,272 posts
Posted 13 April 2006 - 05:07 PM
Evan, not sure you might want to ask Lambs but I've been thinking about going down the R31 rear end set up it's just that I've been getting differing advice.
Lambs. I've checked out a few R31's and it looked like a bit of a pain to get the brackets off. Once the calipers and discs are pulled off how hard or rather what else is involved to get the brackets off?
Thanks
Sulio
#25 Zeddophile
Zeddophile
  • 987 posts
Posted 13 April 2006 - 05:32 PM
This doesn't make sense to me.... do you mean to say she flat spotted her rear tyres? Cause I don't see how you can flat spot brakes....
#26 zedevan
zedevan
  • 1,346 posts
Posted 13 April 2006 - 07:39 PM
yeah....my brains not working...also makes the reason y i put my spare on her car make more sense :D thanks for picking up on it
#27 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 13 April 2006 - 10:31 PM
I'm interested in the rear brake conversion there, but is that $500 for the 3 sets or per set?
#28 Toecutter
Toecutter
  • 2,272 posts
Posted 13 April 2006 - 11:11 PM
If only it were for all 3!
No it's per set. How do you think that price fairs?
What sort of price would the R31 parts cost from a wrecker? Ie calipers, discs, brackets??? and still wondering how hard it is to get those braqckets off the R31 skyline?
#29 lambs
lambs
  • 131 posts
Posted 13 April 2006 - 11:35 PM
R31 rear cals fit under 14" rims (only Silh's and Ti's had 15" rims, all the rest used 14" + all used the same brakes)
Getting the brackets off is fairly simple. Once the cals and discs are off, you'll see 4 nuts behind the axle disc flange. Those nuts secure the wheel bearing retainer (ie hold the axle in place) as well as the brake backing plate and the brackets, which simply slide over studs. Undo the nuts and pull the axle out of the diff housing. Once the axle is out, the brake backing plate and the bracket simply slide off. Sometimes the axle can be difficult to budge, esp if it's been in place for awhile, but a bit of gentle 'persausion' usually works.
As to price, I haven't checked in a long time, but I'd guess a place like Pick-a-Part would want around $30/cal
#30 lambs
lambs
  • 131 posts
Posted 13 April 2006 - 11:40 PM
Your probably looking at around $600 once shipping is added, even using surface parcel post (weight being the main issue).
#31 Huw
Huw
  • 299 posts
Posted 14 April 2006 - 10:23 AM
My car is running skyline rears and stock front.
can't tell you how well they run cause I haven't had a chance to properly 'run it in' (not registered yet) I can tell you that they work......
I little trick with the bracket....
on mine someone had done a bad job converting the rear drums to 280 discs (and I mean a REALLY bad job (explains how many times it was crashed!))
so we had a 280 bracket lying around...all that was required was welding up the holes and redrilling them in an acceptable position.
It would look nicer with a factory one tho (although u can get them plated afterwards (which is what i did).
Anyway, just another option.
Huw
#32 Toecutter
Toecutter
  • 2,272 posts
Posted 14 April 2006 - 10:45 AM
OK thanks guys I'll have another go at removing the R31 calipers and brackets, oh and the rear disc from the R31 is that also a direct bolt on to the S30 rear?
#33 lambs
lambs
  • 131 posts
Posted 14 April 2006 - 02:01 PM
Yes, PCD and centre hole are the same plus the offset is correct to line up with the caliper once the bracket is bolted in place. The centre hole of the bracket needs to be bored to match the OD of the hole in the original brake backing plate. New holes have to be drilled in the bracket to match the original bolt pattern and some grinding of the strut is required to get the bracket to sit flat against the backing plate flange.
#34 Toecutter
Toecutter
  • 2,272 posts
Posted 14 April 2006 - 04:15 PM
Thanks lambs,
Does this thread below look familiar!??? :)
http://www.performan...t-67123179.html
#35 warrenz
warrenz
  • 355 posts
Posted 21 April 2006 - 06:18 PM
Hi
Maybe this ad on OzDat is of interest
240/260z Rear Disc Conversion I have for sale a rear disc conversion for the above,no mods reqd to fit.Has internal handbrake setup
Car Identification: 240/260z
Price: $600.00 Location: wollongong NSW
Contact: Graeme Phone: 0413393616
Warren
#36 Natez
Natez
  • 303 posts
Posted 22 April 2006 - 01:38 AM
http://cgi.ebay.com....1QQcmdZViewItem or this.... finishing soon
#37 warrenz
warrenz
  • 355 posts
Posted 22 April 2006 - 02:48 PM
The winning bid on eBay was $480.
Warren
#38 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 03 June 2006 - 06:35 PM
Hey guys, has anything gone further with the rear disk conversion? Still really keen, wanna try and get the car ready for the Dutton rally soon, would be great to be able to stop even better. I'm currently watching the NSW one up around Canberra and Sydney (friend racing in AE86), giving the Evos and Rexs a flogging on the hillclimbs and some on the motorkanas. Anyone else entering?
#39 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 07 June 2006 - 07:07 AM
Hey, just found these Hilux calipers on toymods, if anyone is interested.
http://www.toymods.n...read.php?t=6276
Could probly do with a rebuild i guess.
#40 240ZR
240ZR
  • 191 posts
Posted 07 June 2006 - 09:20 AM
I just finished my brake conversion on my 260Z... 266mm vented fronts with 4spot Landcruiser's & 280mm solid rear with sigma single piston caillipers. I'm still using the 7/8 M/C bit will be changed to 15/16 to give me a slightly firmer pedal. This set up works quite well with the fronts locking up before the rears under heavy braking.
Let me know what you guys think... I'm also working on the "Maxima bracket" set up but with a 290mm solid disc.
Nick.
