High ZDDP Oil Grades in Australia
35 replies to this topic
#1 240Z_au
240Z_au
  • 280 posts
  • Tagline:Many other, but 240Z since 1987
Posted 16 February 2015 - 10:49 PM
Hi there..
Just completed 300 miles running-in period on my warmly tuned L28. With mild cam, triples and a need for a frequent 7000 RPM, I need oil which will stand up to the task. I saw a few recommendations on Penrite with their high Zinc content, but I see viscosity varies and they dont seem to have a 10W-30 which I'd like to use in my engine.  I see there is Valvoline 10-30W with high ZDDP, but they don't seem to offer this oil in Australia.
Thoughts/Recommendations on the above?. Who uses what in their modified/hard working engines.
Thank you in advance.
Andrew.
#2 dat2kman
dat2kman
  • 4,146 posts
Posted 16 February 2015 - 11:59 PM
Look at Joe Gibbs,
LAT
Brad Penn
All have high Zinc, way way more higher than the so called commnly available "high zinc" oils in the shops.
I use Joe Gibbs xp3/xp6 in ,y engines, extend oil changes, by factor of four, oil ressures and temperature are a little more stable, and on engine tear downs, nowhere near the amount of wipe on bearing shells, compared to your "super dooper modern" stuff.
#3 240Z_au
240Z_au
  • 280 posts
Posted 17 February 2015 - 12:13 PM
Thanks very much. I never considered these brands, my head has been stuck in modern engines for too long so outside the odd Royal Purple, I saw nothing but the mainstream brands.
I checked both the Brad Penn (impossible to buy here, Motorsport Connection in Sydney have no stock till Mid March and another supplier in Melbourne main number is diverted to a mobile)
Then I looked at your Joe Gibbs recommendation, but that's fully synthetic which I guess is where you get the clean tear down benefit from I guess. XP3 looks good, just not sure if Fully Synth is the way to go on an older style engine?. You run low micron oil filter?
#4 pauly_adams
pauly_adams
  • 1,160 posts
Posted 17 February 2015 - 06:16 PM
why are you after such a thin oil ? also penrite's scales is a bit odd so HPR5 will be a 5w30 or 10w30 equivalent
http://www.penriteoi...1&id_products=1
#5 260DET
260DET
  • 2,429 posts
  • Tagline:Tribal Elder
Posted 17 February 2015 - 06:58 PM
Penrite would be my choice.
#6 240Z_au
240Z_au
  • 280 posts
Posted 17 February 2015 - 08:17 PM
So you all run fully synthetic oils?..The old 1970's recommendation was a 10W-40, but of course 10W-30 is thinner and will allow freeer spinning and get to the bearing parts easier, etc. I want an oil with higher ZDDP levels and I see Penrite states "FULL ZINC", but when you look at spec sheet it only contains 0.10%, whereas I'm looking for more like 1%+. I'm afraid mainstream oil manufacturers need to eliminate higher Zinc levels because they need to conform to the modern EPA standards so Penrite is out for me.  I hope I'm not getting too pedantic here, but I do hammer my engines and race them regularly so I need the best protection I can get for the older style engine.
Dat2Kman - Where do you get your oil from?
#7 dat2kman
dat2kman
  • 4,146 posts
Posted 17 February 2015 - 09:57 PM
Current Penrite has bugger all zinc.
Its fine if you just want it for a daily.
I use a combo of 50:50 Gibbs XP3 and XP6, to give a little more viscosity.
Need to be aware of what you mix with what.
Do a bit of research on Diesel oils, different ash and detergent formulations, and higher zincs.
#8 240Z_au
240Z_au
  • 280 posts
Posted 17 February 2015 - 11:29 PM
Thanks..Yeah, I agree re diesel oil, just feeling mentally not ready to run industrial lubricants in my Z :) , but I agree, they tend to have more of the good stuff. I may just go with your other recommendation.
So fully synth all the way for you?. Where do you get a good supply base from in Australia?
Thanks in Advance.
#9 dat2kman
dat2kman
  • 4,146 posts
Posted 17 February 2015 - 11:41 PM
Google Joe Gibbs Oils, shoot them an email asking for the  Vic distributor.
Our guy up here is two suburbs away, they mainly supply speedway and drag race customers, maybe ask similar Speedway/drag type suppliers/shops down your way?
#10 pauly_adams
pauly_adams
  • 1,160 posts
Posted 18 February 2015 - 10:44 AM
I personally run penrite HPR15 15W50 in my z the engine is fairly fresh and can at times cop about 18psi of boost up its back side, the other oil I use is Nulon 15w50 street and track
#11 240Z_au
240Z_au
  • 280 posts
Posted 18 February 2015 - 02:38 PM
Thanks Guys!..Checked Joe Gibbs, but because they apparently changed the name to "Driven" I couldn't see any local suppliers easily. Got two gallons ordered now..Will be cooking this weekend :).. Thanks again.
#12 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 16 March 2015 - 02:24 AM
The Penrite 10 tenths range has at least 2200ppm ZDDP which is nearly double the Penrite HPR range. Ie 0.1% zinc vs 0.2%.
http://www.penriteoi...eg=1&id_brand=3
No oils listed in this thread match that in zinc content.
What info are you referring to that makes you want 1%+?  I haven't found any motor oil with zinc more than 0.2%.
#13 luvemfast
luvemfast
  • 4,160 posts
Posted 16 March 2015 - 10:04 AM
This is a full synthetic oil. I've been led to beleive that mineral oils are better for the older L series engines ???
Also, 15W-50 or 20W-60?
#14 dat2kman
dat2kman
  • 4,146 posts
Posted 16 March 2015 - 10:35 AM
I think you'll find that the Joe Gibbs, Brad Penn and LAT oils are the highest zinc content.
Commercially available in Australia, and come in a range of viscositys, or single weights, and in both pure mineral ( Pennsylvania State) as well as compunded Synthetics.
As for what to run, it depends on clearances and tolerances, and what type f kechanicals are within in engine.
Eg, a multi valve cam on bucket, or cam n follower with very tight tolerances, desigined for high rpm, ie  Toyota 20 V 4AGE would use a 0-20 weight range.
An older cam on rocker, or cam to hydraulic lifter, large soze  two valve head, bigger bore, looser clearances, ie a Ford/GM V8, or a Nissan L series 20-60 weight range.
Its quite possible to run a single weight viscosity oil, f you know what your ambient conditions are, and bring an engine to operating temps before use.
Heavy oils are sluggish and reduce an engines ability to perform well compared to much lighter weight oil.
It's never been rocket science.
#15 Roberto
Roberto
  • 740 posts
Posted 21 March 2015 - 01:53 PM
Yeah, I had a chat to Peter MC earlier in the week and he believes that L-series motors do best with a good mineral oil versus synthetics.  He recommended Castrol Edge 25w-50 which is the only mineral oil in the Castrol Edge range. This viscosity is in line with what the factory recommends for L-series motors too.
I can't comment on its ZDDP content because they do not disclose it and google searches have revealed nothing.
#16 Roberto
Roberto
  • 740 posts
Posted 21 March 2015 - 02:08 PM
http://datnet.org/to...rol-q-a-thread/
More searching has found this thread.  This website indicates Castrol Edge 25w-50 is at lesast 1000ppm zinc.
#17 ZED660
ZED660
  • 180 posts
Posted 10 April 2015 - 10:23 PM
Another option is Pennzoil GT Performance Racing Oil 25w/50 which is still available from these guys
http://www.kynuna.com.au/index.htm
#18 HKSZ
HKSZ
  • 265 posts
Posted 11 April 2015 - 12:37 AM
I run 25/50 Pennzoil GT in my rally car, plus I add Nulon e20 engine treatment to this and all my old engines.
#19 dat2kman
dat2kman
  • 4,146 posts
Posted 11 April 2015 - 12:58 AM
Oils i use range from 8000 to 10,000 ppm.
Kinda nce insurance to have.
Penzoil GT has always been a favourite of Stew Wilkins at SWM.
Hard to find their old formulation good stuff
#20 hmd
hmd
  • 338 posts
Posted 24 April 2015 - 04:56 PM
Penrite HPR 30, 1600+ppm
