R200 longnose diff seals?
2 replies to this topic
#1 Dan260Z
Dan260Z
  • 150 posts
Posted 10 February 2015 - 11:34 AM
Anyone know a part number for these?
I ordered a set using the listing for 260z from here: http://www.alliedbea...ght-commercials
But they came in too small (both OD and ID) for both the pinion and 2 output seals.
I've measured them and came up with
Side seals 55mm x 34-ish (contact area on shaft is 35mm)
Front(pinion) seal 75mm x 39-ish (contact area on shaft is 40mm)
I suspect the parts I actually need are:
400065N (34X55X11)  Part: 34X55R
400087N (40X75X12/17)        Part: PR0260    (no idea what the 12/17 means?  Or if the ID should be slightly smaller than the shaft to ensure it seals against it?)
If anyone could confirm, or supply part numbers, etc it'd be great!
#2 Riceburner
Riceburner
  • 3,266 posts
Posted 10 February 2015 - 07:33 PM
Stuart Wilkins has them listed, $8 & $14 each.
http://www.swmotorsp...h=16_72&&page=2
#3 Dan260Z
Dan260Z
  • 150 posts
Posted 17 March 2015 - 09:09 PM
Cheers!
Unfortunately I'd ended up ordering the ones I noted above before I saw you post - They fit ok, though the side ones were a tad narrow so I had to be careful not to push them too far in.  They're about 2mm narrower than the stockies.  If I did it again I'd get the SW motorsports ones.
