Non symmetrical geometry
7 replies to this topic
#1 Stivva
Stivva
  • 992 posts
  • Tagline:Hiroshima Screama
Posted 27 January 2015 - 08:20 PM
Guys,
Got a query and have had a discussion with my tyres shop guy.
The rear end of my car is non symmetrical? The passenger wheel is about 10mm outside the guard more the drivers side. I was told this was common in nissans. Is this normal, or is it too be corrected, I am aware the cars have no adjustment. The car doeant pull to the side and the guards are the same width.
#2 dat2kman
dat2kman
  • 4,079 posts
Posted 27 January 2015 - 08:28 PM
Can be caused by a decent sideways slide into a gutter. This can deform floorpan at pins that support moustache bar.
Does not take much of a whack!
How is the rear toe readings,,,in,,,on each side??
Wheel backspacing same on each side?
A commn fix to pull toe on one side is to cut the front of the rear arm, and pull it inwards and re-weld plates over the slit.
Fitting eccentric lower rear arm bushes can dial a bit of toe in/out, but not a great deal.
Delrin is a more forgiving hard plastic to use, you'll need a machine shop!
#3 d3c0y
d3c0y
  • 2,925 posts
  • Tagline:Forum Jerk
Posted 27 January 2015 - 10:26 PM
Every zed i have seen is like this pretty much.
#4 gilltech
gilltech
  • Donating Members
  • 1,172 posts
Posted 27 January 2015 - 10:33 PM
FWIW, 10mm sounds too much IMO. I had the alignment of my 260 checked on one of those car-o-liner things, IIRC the chap told me that up to 3mm is acceptable.
Get someone to follow you down the road - does your car appear to crab so that you can see more of one side than the other? Not uncommon, I've noticed it quite often on various cars - old & newer - that look perfectly fine otherwise. Usually means the back axle is out of alignment with the body shell. Sideways into a kerb on a wet road can be enough to do that.
If it were me I'd put the car on 4 jackstands, minus wheels, steering straight ahead, & take measurements down both sides & diagonally as accurately as I could manage, & across & diagonally around the rear suspension, to see if I could spot where a possible deformity might be. Then depending what I found I might consider getting the car checked professionally.
#5 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 27 January 2015 - 10:55 PM
I am sure there was a thread about this exact issue a while back, but I can't find it now.
However, this may be worth a read, not exactly your problem but..........
http://www.viczcar.c...pic,7997.0.html
#6 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 28 January 2015 - 10:08 AM
Same all my zeds have been like this.
Is very annoying when trying to get wheel in that just fits on one side and scrubs on the other, as i am finding out at the moment..
#7 Stivva
Stivva
  • 992 posts
Posted 28 January 2015 - 07:00 PM
fitment - exactly what my issue is currently lol!
#8 d3c0y
d3c0y
  • 2,925 posts
Posted 28 January 2015 - 07:21 PM
Adjustable rear control arms is your answer!
