Sign in to follow this
G
Rear control arm re-bushing help
I'm currently rebuilding my rear end with new nolathane.
The inner part of the rear control arm appears to need a metal bush which slides over before the nolathane bush goes on.
Is this correct? I just don't understand why there's metal on metal contact if so...
Share this post
Link to post
Share on other sites
Yep that's correct. The arm is meant to pivot within the sleeve. I just applied a healthy amount of wheel bearing grease to the control arm before fitting the new bush.
I still use OEM ones as I read the urethane can cause binding.
Share this post
Link to post
Im having difficulty getting lower arm bushing. If there any other nissan cars that uses the same bushing? Or where can i get these?
Share this post
Link to post
Stewart Willkins sourced mine, they are Whiteline product, similar to above but are a one piece instead of two piece.
Rudi
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
