Rev's new Zed
141 replies to this topic
#101 oldmates260z
oldmates260z
  • 753 posts
Posted 27 May 2015 - 09:50 PM
So now we are on Facebook  :o ..... But a good idea.
#102 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 27 May 2015 - 09:57 PM
Yeah but without the narcissism and selfies. :)
#103 MaygZ
MaygZ
  • 1,458 posts
Posted 31 May 2015 - 07:58 AM
Coming soon to a forum near you!
We could have a system whereby we could score people for good and bad.  Perhaps we could call it 'karma'.    ;D ;D ;D ;D
Great work Dave.
#104 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 31 May 2015 - 06:29 PM
Great work Dave.
I noticed that the screen shot showed "warning points"
Interesting territory to head into ?
#105 reverendzed
reverendzed
  • 1,717 posts
  • Tagline:I'm Dave & Yes! I'm a real Revhead..er Reverend...
Posted 06 June 2015 - 10:39 AM
Update on interior: Got passenger seat finished and have started with interior.  I'd plastic welded the multiple cracks in the rear garnishes, then upholstered it in the pressed vinyl - with plenty of heat and high tack spray glue it turned out amazing.
#106 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 06 June 2015 - 11:44 AM
I like the pressed vinyl on the 1/4 plastic. Looks OEM. I actually prefer the flatter pressed vinyl over the more padded look on the strut towers.
Interior should look good when it is back together.
#107 reverendzed
reverendzed
  • 1,717 posts
Posted 08 June 2015 - 06:22 PM
Got some more done today thank you to the Queen! Happy Birthday!
#108 KatoKid
KatoKid
  • 1,695 posts
Posted 09 June 2015 - 02:50 PM
I picked up my pressed vinyl kit from Dave on Sunday and can attest to how good this looks in the flesh
#109 reverendzed
reverendzed
  • 1,717 posts
Posted 13 June 2015 - 06:23 PM
After enough hassle of poorly fitting carpet I decided to make a fresh template and do my own - Took some time but fits better than anything I could get off the shelf!  going to do the same with the fronts.  Also removed the dash and have begun to do my own resto.  I've taken all the cracks as deep as possible, ready to be filled.  I'd sanded the top passenger side and played with some application techniques to see what the finish might look like - pretty pleased with the outcome.
#110 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 13 June 2015 - 08:24 PM
Hey Dave,
What are you using on the dashboard to fill the cracks? Expanding foam? I guess you're using truck bed liner spray or that SEM textured finish for the top? I should experiment with this also.
#111 reverendzed
reverendzed
  • 1,717 posts
Posted 13 June 2015 - 08:26 PM
I'm still considering what I'll use Gav - I'm a bit worried about the expandafoam and wondered if I shouldn't just use Resin or Sikalex to fill the cracks.  It wasn't a huge pain to pull it out so if I trial this and it lasts me a couple of years, it's still worth a go.
#112 Lurch ™
Lurch ™
  • 5,662 posts
Posted 13 June 2015 - 08:58 PM
Is this for sale yet?
#113 reverendzed
reverendzed
  • 1,717 posts
Posted 13 June 2015 - 09:13 PM
The Poms keep emailing me!
#114 Lurch ™
Lurch ™
  • 5,662 posts
Posted 13 June 2015 - 09:29 PM
I'm not surprised!
I see you're already looking for a new project! http://www.gumtree.c...260z/1066523510
#115 reverendzed
reverendzed
  • 1,717 posts
Posted 13 June 2015 - 09:41 PM
an additional project - there's a difference! another doesn't mean forfeiting the other! ;)
#116 reverendzed
reverendzed
  • 1,717 posts
Posted 22 June 2015 - 07:33 PM
Update on the DIY dash resto! After carving out the cracks and excavating under the surrounding vinyl or the cracks I filled with 'expandafoam'.  Once that had set I then cut down around 1.5cm to give sufficient depth to the bumper filler that I used as the solid substrate.  I built this up and sanded between layers to check height and adhesion.  I ended up putting a skim coat over the major affected areas and sanded it all to shape.  I was still concerned that the rest of the vinyl was easy to crack just by pressing my finer into - not wanting to fibreglass I had this crazy idea of sanding (for adhesion) and them applying POR-15.  POR-15 sets rock hard so I applied 4 coats, sanding every 2 coats.  After the last coat I sanded for a nice flat finish and then applied Texture bumper paint which has given me a light sheen textured finish without the 'high gloss' - pretty happy with the outcome - total cost $55.00!!
#117 PB260Z
PB260Z
    Peter (PB)
  • 3,283 posts
Posted 22 June 2015 - 08:19 PM
Hi Dave
That looks pretty darn good, and for only $55 - sensational result
#118 Zedman240®
Zedman240®
  • 5,198 posts
Posted 23 June 2015 - 08:50 PM
Hi Dave
Couldn't have said it any better! Well done Rev!
#119 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 23 June 2015 - 09:29 PM
Well done Rev.
Posted Image
#120 Gordo
Gordo
  • 1,112 posts
  • Tagline:Racing member.
Posted 23 June 2015 - 10:10 PM
Well done Rev. Any dashboard work is very time consuming . Many hours there mate. Just goes to show if you have the passion you can achieve greatness. What's next?
