Novice needs help fitting 240z steering wheel pleeease !
22 replies to this topic
#21 Mr Camouflage
Mr Camouflage
  • 986 posts
  • Website:http://www.wazcars.com
  • Tagline:www.wazcars.com
Posted 30 December 2014 - 01:56 PM
Well further to this, I've just compared the back faces of the 240 & 260 steering wheels, & they look identical.
From looking at the 240 wheel pic one of you posted, the bit I'm missing is whatever the little black wire attaches to on the front face - on the 240 wheel I bought there's just a hole, whereas there must be meant to be a little captive nut, to screw into, maybe with an insulation collar around it? Can someone please advise?
Can you post a picture of your wheel centre. From what I've seen in your other thread, it looks like you might be missing the upper ring. See exploded diagram below. From memory, the upper ring had a threaded punch hole that the screw screws into, and the ring directly below it has a cut out for clearance.
#22 Mr Camouflage
Mr Camouflage
  • 986 posts
Posted 30 December 2014 - 01:59 PM
exploded view
#23 gilltech
gilltech
  • Donating Members
  • 1,305 posts
Posted 30 December 2014 - 02:23 PM
Thankyou!!! for all your help.
That explains it, I'm missing that upper ring #18 & whatever little bolts/nuts/washers #24-28 come with it; I have two push-on padded horn caps but they're both 'empty'.
I'm also missing the spring #21; the 260 one is too large in diameter.
Oh well, at least I finally know what I'm missing & will just have to keep my eyes peeled.
PS. my metal ring part #22 floats up & down on screws atop the nylon ring #19. I presume that the missing ring #18 is also supposed to be secured by those same screws.
Not the sort of odd part anyone's likely to have lying around, I'll try advertising but suspect I'll just have to replicate it.
