Clutch bite point changes
6 replies to this topic
#1 fbr
fbr
    Member
  • PipPip
  • 26 posts
Posted 26 November 2014 - 09:46 AM
Hi,
Sometimes when I'm driving the clutch bite point is in what I'd describe as a normal position, (a few inches off the ground) and then other times be just a few centimeters. It's not the case of after it warms up it stays in one position or another appears random.
Would anyone know the cause the fix?
Thanks,
Tim
#2 1600dave
1600dave
  • 664 posts
Posted 26 November 2014 - 10:04 AM
Lack of fluid in master cylinder - leaking master cylinder / slave cylinder.
#3 gav240z
gav240z
    Administrator
  • 13,219 posts
Posted 26 November 2014 - 10:54 AM
+1 only thing I can think of that would cause it to change.
#4 oldmates260z
oldmates260z
  • 753 posts
Posted 26 November 2014 - 12:51 PM
It may vary as if it is low and you use the clutch a few times quickly it will pump out any air. Suggest you look for fluid around where the shaft from the top of the clutch lever goes into the cylinder on the firewall and also take the rubber boot off the slave cylinder (with safety glasses on, OH&S  ;)) on the gearbox and see if any fluid drops out of there.
Only other thing is if the pressure plate is starting to fail but that should be consistent
#5 1600dave
1600dave
  • 664 posts
Posted 26 November 2014 - 01:01 PM
Fix is to buy new cylinders, fit them and bleed the system.
You should be able to pick up the whole lot (both cylinders, new brake fluid, and maybe the rubber hose on the slave cylinder) for under $100 - not a bad idea to replace the lot anyway if its a bit "iffy" and treat it as preventative maintenance. Cheaper than a towtruck when it fails completely (which it may well do at the most inconvenient time).
#6 fluegel
fluegel
  • Donating Members
  • 110 posts
Posted 29 November 2014 - 02:44 PM
Don't forget to bleed the master cylinder as well
#7 fbr
fbr
    Member
  • PipPip
  • 26 posts
Posted 05 January 2015 - 12:51 PM
update - bled the system, changed fluid problem still there so changed master and slave over the break and problem solved. thanks all.
