BC coilovers
26 replies to this topic
#1 mossy
mossy
  • 1,770 posts
Posted 31 October 2014 - 05:39 PM
Just noticed these are now in stock at the Australian distributer.
http://www.bc-racing...51mm-strut.html
#2 KatoKid
KatoKid
  • 1,663 posts
Posted 31 October 2014 - 06:09 PM
........and then😜
#3 pauly_adams
pauly_adams
  • 1,160 posts
Posted 31 October 2014 - 10:26 PM
they are just s13 coil overs, you can do this to most base height adjustable s13 coils, you need to cut off the knuckle and weld it to the base height adjuster and your done
#4 mossy
mossy
  • 1,770 posts
Posted 01 November 2014 - 08:31 AM
........and then😜
No I haven't bought any for my 240  ;D
Going from the thread here at Hybridz http://forums.hybrid...30-time-to-buy/ it looks like it took from early March to early July for the first test kit to arrive so I thought they would be more than just s13 coilovers?
#5 d3c0y
d3c0y
  • 2,847 posts
  • Tagline:Forum Jerk
Posted 01 November 2014 - 12:33 PM
The coilover strut part is pretty much the same for most car models for each coilover manufacturer ie McPherson strut type or double wishbone. They just change spring rates, valving and top and bottom mounts to suit the different cars. I have WRX struts from MCA, for the reason that it featured inverted monotube front shocks. Obviously i had a set of zed strut tops and some threaded tubes to suit made up so you can cut the tube off the factory strut and weld this threaded tube onto the bottom knuckle and bobs your uncle, 240Z coilover from WRX ones.
You have been able to order that setup on a complete strut of Tein Japan for years.
#6 mossy
mossy
  • 1,770 posts
Posted 01 November 2014 - 01:18 PM
I think there are a few in japan that do them, (tein, ohlins, aragosta) just need to send in your struts to modify, and they cost a pretty penny.
#7 d3c0y
d3c0y
  • 2,847 posts
Posted 01 November 2014 - 03:57 PM
MCA in QLD $2500, welded ready to go.
#8 Yo-Yo
Yo-Yo
  • 156 posts
Posted 03 November 2014 - 08:20 PM
Is that for a set up like yours? ie WRX modded to fit
I think I need to start emailing them  :)
#9 d3c0y
d3c0y
  • 2,847 posts
Posted 03 November 2014 - 11:20 PM
Surely is, I reckon if i wanted to i could put the chassis rails on the ground with this setup and still easily run legal ride height and then some.
Full run down on my facebook page of all the measurements we did for MCA and installation in two cars. It's not really modified to fit either, it's a set of coilovers that have 240z attachments fitted to them, opposed to WRX.
Also as a note to others doing this, I had HKS Performa coilovers (GDB WRX as well) which I originally intended doing this with and they weren't going to provide the right amount of travel in the front. So moral of the story all coilovers are not equal, do you measurements!
#10 bryan3976
bryan3976
  • 365 posts
Posted 25 January 2015 - 05:50 PM
im considering these but i have 55mm struts might need a little modding but should fit . has any one got these ?
#11 Jap Metal
Jap Metal
  • 31 posts
Posted 12 February 2015 - 11:12 PM
Yes I have a set  for 240z 50mm  struts
You can order  50mm  or 55mm    versions
And  custom spring rates
Any bc distributor  can get them for you
I got mine from    centerline suspension  in Thomastown Victoria in 2014
They are well priced    for a two  way adjustable coil over with camber tops
I doubt you could make a kit your self using  s13 or wrx  and then making camber tops  , measuring heights etc
For the same price
And why would you when you can get a off the shelf  kit
#12 24TZ
24TZ
  • 94 posts
Posted 13 February 2015 - 07:51 AM
For the same price
Because BC coilovers are not even close to the quallity of MCA suspension.
Ive have been 2 cars with BC's (180SX and 32 GTR) and both were very  average, the adjustment on the valving does nothing IMO.
I went straight to a custrom Tein Monoflex setup for my GTR and they are miles ahead. I had contacted MCA before I bought the Teins but they were still in the prototype stage for 32 GTR and I couldnt wait any longer. They did offer me custom gold series but at over $5k i couldnt justify that for how i use the car.
In saying that  BC's might be fine for how some use their cars.....
#13 Jap Metal
Jap Metal
  • 31 posts
Posted 13 February 2015 - 04:28 PM
Fair enough
What year were  you wanting  to purchace the Tein's ?
The bc you had experience with were  ,V1 series, BR series , RM series , or  ER series ?
I have had no experience with MCA  'I know they do TIME ATTACK ' so they should be  Top Quality  good gear
don't get me wrong ,but they had no off the shelf kit
Did you get the Blue or REDs  ?
Do you know what brand  Shock inserts they use ,or company that manufacture for them  ?
Good brands I know of  are    Bilstein  ,Koni  , Tein
most aftermarket  Coilovers are made overseas    like  Taiwan  then  branded
And  you can get  -  budget series    -  midrange series  - Top of the line Series
You get what you pay for
My 240 is a Street car  which will see  some track time
And  Iam not a Professional Racing Car Driver
And For  $1350  I am happy with my purchace  ATM
#14 phillay
phillay
  • 292 posts
Posted 16 February 2015 - 09:16 AM
Fair enough
hey jap metal
have you got your BC coil overs welded on yet? did you welded them on yourself? Did they come with some instructions?> if so would you mind sharing them to me? I want to see how they work before getting a set. cheers
#15 Jap Metal
Jap Metal
  • 31 posts
Posted 18 February 2015 - 12:00 PM
I have only setup one side on my car
As I  doing  more suspension work/ mods
Instructions and pic of  one rear
if you weld your self  I recommend you pre heat casting and strut tube - to get better penetration
#16 d3c0y
d3c0y
  • 2,847 posts
Posted 18 February 2015 - 03:36 PM
What's your compressed length on the strut, from the spindle to the top of the camber plate? That camber top adds a lot of height to the top of the strut.
#17 Jap Metal
Jap Metal
  • 31 posts
Posted 18 February 2015 - 07:22 PM
Yeah I was concerned of that when I first got them (not having enough travel )
Its about 60mm    from  top of camber top to  spring
Camber tops add to that because pillow ball is lower than  most other coilovers I have used in different cars  (normally 40mm from what I remember)
That image is a rear    spring length is 220mm    and shock has 130mm travel
installed  spring compresses  about 25mm  so  their is    105mm of travel left for  the shock
front springs are shorter in length  I need to measure
should get a chance on the weekend
From what I know ,and going of what people say  you only need  about  75mm to 100mm of travel left in your shocks and if you are bottom out you need stiffer springs
depending on you application  I guess  ,and iam no expert
The camber tops are made recessed  so you don't need to cut out  strut tops on  the car body if you don't want to
if you don't want to use weld in camber tops, or  even Ground control camber tops ,which still need cutting away at the body and re drilling new holes
This is one way to keep your body un cut
saying that ,I am going to open up the  center hole  on the  strut tops on the body of my  car
so you can adjust camber on the fly
but it wont be as extreme as  other options
wouldn,t mind seeing MCA  camber tops or any others
Its a good way to  compare  options available out there for the zeds
another image  of camber tops
Hope this makes sense
#18 d3c0y
d3c0y
  • 2,847 posts
Posted 18 February 2015 - 09:30 PM
I didn't do camber tops at this point because the car has adjustable control arms front and back and with out the camber top, the strut top is only taking up 10mm. The stock one is 40mm, so you are already 20mm higher than stock in fixed length.
Are you running flares and are you planning to run the car low? On the front of the other car I setup with MCAs, it had 75mm of travel not including the bump stop which is 10mm and personally I will probably be running it around 60mm on my own car to get it low enough. This was using the shortest shock we could in an inverted mono tube for the front.
#19 Dr.J
Dr.J
    Newbie
  • Pip
  • 5 posts
Posted 02 March 2015 - 10:51 PM
I have BC BR type coilovers in my SW20 MR2 and am quite happy with their performance. The car sees at least 6 track days a year, and I find them easy to adjust from the soft road setting, to harder track settings. There is a BIG difference between the settings!
I was looking at some BC coilovers for my 260Z 2+2, but am getting confused/concerned about original widths and lengths of the OEM setup. Apparently the later Zeds, (mine's a 1977) have larger diameter
springs and shocks? I don't want to buy the wrong thing.
Also I've bought wheels, (15x9" 0 offset) that are too wide and foul on the spring perches, so I'm looking for a bit more clearance which is why a coilover setup will make more sense.
#20 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 03 March 2015 - 07:55 AM
With that style of camber plate i don't think your going to be able to get the car low enough and have sufficient travel.
