Breakdown in Clem 7
29 replies to this topic
#21 Riceburner
Riceburner
  • 3,266 posts
Posted 17 July 2014 - 06:14 PM
Thoughts on this? Judging by the heat in the ignition module, I would have thought that would have been more conducted from the engine rather than from the functioning of the unit?
http://www.atlanticz...uild/index.html
Very good idea! My old dizzy was set up this way before I went to the msd. The module was mounted below the inspection lamp.
#22 Zedman240®
Zedman240®
  • 5,198 posts
Posted 17 July 2014 - 06:58 PM
If you want to test the ignition module, while the engine is still cool, grab a heat gun and heat it up. If it dies, that's it. Then cool it off with a wet rag and see if it starts again.
You can wire in a Bosch "022" type module but just have to wire in another couple of wires to it.
#23 dat240z
dat240z
  • 1,120 posts
Posted 17 July 2014 - 07:26 PM
I had a pretty similar problem before my conversion. Car would just stop, wind over, but not fire. Lots of fuel. Turned out being my dodgey fuel pump. Is fuel getting to your carbs? Undo a house and see, if not Maybe try giving yours a whack if it plays up again.... T
#24 dat2kman
dat2kman
  • 4,085 posts
Posted 17 July 2014 - 07:57 PM
You watch.
Murphy's law will be invoked.
You'll fit a replacement, and slip a spare in the glvebox,,,,,,, and you will never ever need the spare!
#25 nizm0zed
nizm0zed
  • 1,312 posts
Posted 17 July 2014 - 08:26 PM
You watch.
thats called cheap insurance, underwritten by Murphy and Sons.
#26 OZZ240
OZZ240
  • 40 posts
Posted 17 July 2014 - 08:54 PM
Would a coil breaking down cause these same issues?
#27 nizm0zed
nizm0zed
  • 1,312 posts
Posted 18 July 2014 - 08:07 AM
Yep,
A coil on its last legs can definitely fail under a high heat/load situation.
Most frustrating bit about that is it'll usually measure ok, so it can be a pain to diagnose.
#28 Lynton
Lynton
  • 538 posts
Posted 18 July 2014 - 12:21 PM
likewise a fusible link could do this, keep the engine running and give the wires a wiggle if faulty engine will stall lynton 8)
#29 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 18 July 2014 - 12:26 PM
Thanks for all the tips and ideas.
The coil is quite new (only a year or 2 and I don't drive the car much).
Hard to test the fuel situation as it is now running completely fine so I would have to wait for it to breakdown again to check. I couldn't check anything in the tunnel because you aren't allowed out of your car :(
Last night I replaced the ignition module with a spare and put on a new dizzy cap and rotor button as I just happened to have them lying around. Didn't take it for a long drive as it was late, so will test out more tomorrow. But it ran better than usual and didn't miss a beat :)
#30 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 18 July 2014 - 12:29 PM
Ah yes Lyton, I did think fuse when it happened but then kinda forgot to check them once it was running again. Will also check tonight  8)
