thermostat housing
8 replies to this topic
#1 phillay
phillay
  • 292 posts
Posted 12 July 2014 - 03:19 PM
hey guys
I noticed some coolant spraying on the manifold so I went to buy a new hose and clamps, then saw how the housing has rotted away. I tried to undo the bolt and it has snapped so I took the whole housing out. There is what I think is a temp probe. and 2 wires, I goes to the distributor and one goes to i think is 12v. They seem to be stuck I can't undo the nut and I think it will break if I tried harder. I tried to find one of ebay but I am having no luck, does anyone know where I can find the bottom housing just incase I break the thing?
Posted Image
#2 Lurch ™
Lurch ™
  • 5,602 posts
Posted 12 July 2014 - 03:44 PM
Available new from Nissan, Phil
#3 phillay
phillay
  • 292 posts
Posted 12 July 2014 - 05:15 PM
great thanks mate
#4 andyk_79
andyk_79
  • 610 posts
Posted 12 July 2014 - 08:29 PM
If you've got little drops of water spraying it's worth checking the water pump as well. Apparently a worn front seal on these is very common, although that probably wouldn't be spraying the manifold
#5 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 12 July 2014 - 09:46 PM
Top part of thermostat housing is available from Repco for about $12
Housing that bolts to the head is Nissan only.
Cheapest I have found was on eBay.
Here's Doug
#6 phillay
phillay
  • 292 posts
Posted 14 July 2014 - 02:14 PM
the bolts on the head on mine looks ok, but they could do with new ones, the temp sensor fitting looks like its seized on the housing.. just noticed that theres a slight chip and Im not sure if I should change the bottom one as well, it's going to be a long wait if I have to get it from nissan. Just ordered the top part (cover) the bolt is broken and I gotta drill it out. Nothing is ever easy on this car, was meant to only change a hose and clamp lol.
#7 Lurch ™
Lurch ™
  • 5,602 posts
Posted 14 July 2014 - 05:01 PM
Don't drill it out Phil - you'll stuff it.
#8 Cozza
Cozza
  • 903 posts
  • Tagline:Datsun obsessed
Posted 15 July 2014 - 07:32 AM
I got this housing and all the heater hoses, heater tap and firewall grommets from SWM it was about 3 days to be delivered.
He seems to be able to get almost anything.
Mick
#9 phillay
phillay
  • 292 posts
Posted 16 July 2014 - 08:27 PM
all good now guys I got the housing, and replacement hose to the manifold from the usa and the gasket to the head for 110 delivered.
I read somewhere the bolts to the head are a nissan item, mine looks ok but I wouldn't mind replacing them as well. called nissan they said I need to buy 8 of them... lol...
