Help, Strut top hat stripped thread.
23 replies to this topic
#21 d3c0y
d3c0y
  • 2,847 posts
  • Tagline:Forum Jerk
Posted 04 April 2014 - 10:20 AM
I would check out these if that is your issue then:
http://www.k-mac.com...tsun/datsun.htm
From what i read on hybridz they will give you more than -1.
#22 Gareth. J.
Gareth. J.
  • 3,237 posts
Posted 05 April 2014 - 06:43 PM
Interesting, they're a little more than I was hoping to spend but that always the case  ::) It's a Datsun after all!
Do you know any more detail on them Jake? Like height compared to stock isolators and is it just those two cap screws that lock them in position?
#23 d3c0y
d3c0y
  • 2,847 posts
Posted 06 April 2014 - 12:58 PM
They bolt in and require no cutting. They are also the same height as factory 240z insulators. The other really cool thing is they can do camber and castor at the same time, so when you get to the track you crank the camber up and when you are finished put it back to a nice -1.5 degree road spec to save the tyres.
#24 Gareth. J.
Gareth. J.
  • 3,237 posts
Posted 07 April 2014 - 07:50 PM
Thanks Jake. If I go with them I'll post up some info.
