A Lime 240Z spruce up
50 replies to this topic
#21 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 08 June 2016 - 08:55 PM
Hi Mate
Great progress. I love the airbox and have been waiting to see someone do something along those lines.
PB
#22 WA240Z
WA240Z
  • 209 posts
Posted 09 June 2016 - 08:26 PM
Thanks guys, for those who asked here is a photo showing the back plate.
  • gav240z, Ponyo240z and mspecr like this
#23 GK510
GK510
  • 89 posts
  • Tagline:On the never ending quest that is Datsun ownership
Posted 09 June 2016 - 10:38 PM
Looks great all round. I can only hope to get my car to a similar standard one day.
Hopefully I get to see it in the flesh on the streets of Perth.
#24 d3c0y
d3c0y
  • 2,919 posts
  • Tagline:Forum Jerk
Posted 15 June 2016 - 06:34 PM
In reference to your earlier post (and I'm no expert), but pretty sure you are loosing some HP through the lack of volume in that airbox with 44s behind it. In addition to that your really short velocity stacks will be costing your some torque.
#25 gav240z
gav240z
    Administrator
  • 12,743 posts
Posted 17 June 2016 - 06:10 PM
I also managed to hunt down an elusive E88 closed chamber, kidney shaped, cylinder head.
Is that head from an R30 skyline? The EFI version of the E88? If so we can add it to the reference guide here.
http://www.viczcar.c...6-engine-heads/
#26 WA240Z
WA240Z
  • 209 posts
Posted 17 June 2016 - 10:57 PM
D3c0y, I agree that the air box could well be hindering performance I will know better in a few weeks when I get a chance to have the car on a dyno. The modified airbox to suit the mikuni's was something I have wanted to do for sometime, more do with the finished product I wanted to achieve rather than outright HP. The money I spent on having professionals build my original L24 would have netted greater HP if I had invested the money in an L28 based build, but an L28 wasn't what I was going for. When I compete in some club competition, sprints etc. I will likely remove the airbox and fit longer full radius ram tubes. But for street driving the airbox should be fine, and it completes a look I wanted to achieve.
Gav, the head is an E88 closed chamber, as you can see from the photo, But I have no idea what it originally came off I can only presume it was the EFI head. I am pretty sure it was 39cc chambers. The head is giving, with the eye browed pistons and slightly relieved block for the larger valves around 10.25:1 with 83.5mm bore and 73.7mm stroke. I did spend some time searching for it as all other E88 heads I had seen were open chamber. Before the engine was rebuilt it only had 69000 genuine miles on it and it was kept in good tune and serviced very regularly. But the torque with this new head, even before fitting the mikuni's is fantastic, I can only imagine just how good an L28 based build is if done properly.
Billy.
#27 600Z
600Z
  • 280 posts
Posted 18 June 2016 - 04:32 AM
Hi Billy,
I have the same head that I will be using on my wife's 260. It will be going on a L28 with 87mm bore, triple 45 dellorto's etc.
Just wondering if you did much with port size as from what I understand optimum port size is really about 34 to 36mm for a given 44mm intake valve and displacement to keep the air velocity up within the port.
I'll have to remove a bit out of the chambers to keep the compression down at 10:1 which will be good as I will be able to unshroud the valves.
Justin
#28 WA240Z
WA240Z
  • 209 posts
Posted 18 June 2016 - 09:25 AM
Hi Justin,
Sounds like a very nice build you are undertaking. Yes my head had a lot of work completed on the ports and bowls, sorry I don't have the port dimensions, the inlet ports are the same size as the gasket and the exhaust ports just under the size of the Stewart Wilkins exhaust header, this was to reduce reverberation (I think that's the word). The photo is a bit blury unfortunately but it shows some of the port work.
The head head work, compression and ignition timing was all specifically done for the original Nissan Motorsports inlet manifold and Mikunis as that was my build plan all along.
Gav, happy for the above photos to be included in the head section if they are useful for others. Unfortunately I don't have a photo of the ports before they were worked on.
#29 Riceburner
Riceburner
  • 3,263 posts
Posted 18 June 2016 - 11:29 AM
Top shelf Billy! This car just keeps getting better and that airbox looks like it came from the factory.
What's the plan with the Dyno, will you do some runs with it on and some with it removed for the comparison? It will be interesting to see, someone on the forum used a prince GTB airbox on their Z and that provided gains over open stacks IIRC. I think the GTB airbox is smaller than this?
#30 600Z
600Z
  • 280 posts
Posted 18 June 2016 - 08:48 PM
Hi Billy,
Thanks for the pictures, looks very good. What valves and springs are you using?
Yes they say the exhaust works better if there is a step from the head to the headers.
I'll be keen to know what it produces on a dyno Stewart's headers are fairly expensive aren't they? Do you know the size of the primaries?
Justin.
Edited by 600Z, 18 June 2016 - 08:53 PM.
#31 WA240Z
WA240Z
  • 209 posts
Posted 19 June 2016 - 10:54 AM
Hi Justin,
The Stewart Wilkins headers are well priced I think honestly for both the quality that you get and the knowledge that they have been designed, tested, modified and tested over the years to offer the best torque and performance. I also had mine ceramic coated. I am a away for work at the moment so will check the primary pipe sizes and lengths for you next weekend. Though I am sure someone else on here will be able to supply that info, or just give Stewart a call this week, he is very helpful.
One thing to be mindful of using his headers, they will only fit with certain intake manifolds. I know I needed to file my Nissan Motorsport inlet manifold's cross brace sections so it all mounted up nicely. When I ordered mine he told me that there would be clearance issues with some inlet manifolds, best give him a call to discuss your setup.
Billy.
Edited by WA240Z, 19 June 2016 - 05:27 PM.
#32 600Z
600Z
  • 280 posts
Posted 19 June 2016 - 07:07 PM
Thanks Billy, I'll give him a call.
#33 WA240Z
WA240Z
  • 209 posts
Posted 26 June 2016 - 08:09 PM
So another quick update, I purchased a Les Collins overhauled 260Z gearbox with 2.9 first gear and short throw shift conversion two weeks ago. I pulled the old 3.3 first out and installed the new one yesterday. I now understand why everyone loves that gear ratio set so much. 1st-2nd and 2nd-3rd ratio spreading is so much better, and the short throw shift is really nice to use as well.
After I had the gearbox in and tested I spent a bit of time this afternoon working on my mikunis to get better throttle response and A/F ratio readings. I leaned them out two steps down to 140 main fuels and also brought the airs down to 190 to level the A/F ratio out across the rev range a bit better. Its driving very nice, but its still quite flat between 3000 to 4000 rpm, it may be because of my short velocity tubes. So I think its time to get in on a dyno and tuned properly now. Will hopefully have another update in a couple of weeks.
Billy.
  • gav240z, scott and CBR Jeff like this
#34 gav240z
gav240z
    Administrator
  • 12,743 posts
Posted 26 June 2016 - 08:12 PM
Awesome I'm going to get my 260z close ratio box rebuilt for my 72 240z. I also want to install a 4.1 R180 LSD, thinking of slapping the Triple Mikuni 44's on it also. I can't wait to see what difference it makes.
I'm envious because I really want to get to the point where I have the early 240z up and running and can spend my weekends tinkering with carbs ;). Honestly I do, I have loads of fun doing stuff like that.
#35 WA240Z
WA240Z
  • 209 posts
Posted 23 July 2016 - 05:01 PM
Finally was able to get a day off work and get the car onto a dyno and tuned properly. The car is very smooth with great torque and power, I'm very happy with the end result. The surprising thing was my cut and shut air box, with the air box on it made an extra 4hp, so happy with that also. Time to start really enjoying the car with the new setup and stop working on it.
  • gav240z and scott like this
#36 d3c0y
d3c0y
  • 2,919 posts
Posted 24 July 2016 - 12:23 AM
4HP in comparison to what?
#37 scott
scott
  • 199 posts
Posted 24 July 2016 - 01:25 AM
how much hp/torque did u make in the end?
Interesting result with the airbox as well.
#38 Cozza
Cozza
  • 988 posts
  • Tagline:Datsun obsessed
Posted 24 July 2016 - 07:08 AM
Yeah, what was the other setup?
A graph comparison if you had one would be very interesting.
I do like your air box. :)
#39 WA240Z
WA240Z
  • 209 posts
Posted 24 July 2016 - 03:34 PM
Hi Guys,
The extra 4 RWHP was with the air box with 25mm ram tubes, air filter and cold air piping fitted compared to just the backing plate with the ram tubes. The A/F ratio was ever so slightly leaner with the air box fitted so the extra HP may have come from that.
The two different scenarios below.
Final result was 155 RWHP @ 6,500rpm and 185 Nm @ 4,950rpm. The torque curve was pretty well flat from 4,200 - 6,200rpm. On the road it has a nice steady idle @ 1,000rpm with a bit of torque down low for pottering around on the street, but it really comes alive at about the 3,500rpm mark and pulls smoothly all the way to the 6,500rpm ceiling I am setting for the engine. Also I have to be honest the car feels much quicker than the dyno results show, comparing to my 225kw- 440Nm daily driver, the 240z feels every bit as quick once up over 4,000 rpm. I guess at the end of the day the dyno is a great tool for tuning but the real proof in the pudding is on the track. Will see how my little engine goes against some of my mates with their Z's at upcoming sprints.
The engine specs are:
Original L24 with 0.5mm overbore to 83.5mm, standard stroke.
Original con rods.
Cast flatop pistons.
E88 closed chamber head, 39cc with port, bowl and chamber work.
44mm inlet and 35mm exhaust valves.
10.2:1 compression
Billy
#40 WA240Z
WA240Z
  • 209 posts
Posted 24 July 2016 - 03:54 PM
Also a couple of pics of the completed underside.
  • Sirpent and scott like this
