Central locking
Rod F
I have. I made a tin bracket for the actuator. It was a bit tight but just took a little patience. Once installed I got the wiring connected to an alarm I later installed and I use this alarm remote to lock and unlock the car. Works great, when the alarm is armed the car locks and vice versa.
Sulio
Link to comment
Share on other sites
if your looking for a simple alarm system with the central locking
best bet is to go on Ebay and buy something off there you like, unless you want a brand name...
as all the $3-400 stuff i find in jb-hifi etc etc, is all made in the same factory in china, and will cost you 150 or 200 on ebay... i did this and bought the actuator from JB-HiFI, as thats the heavy duty part you need, saved a few hundred dollars
Link to comment
