Wanted: 260z heater tap
7 replies to this topic
#1 classicZ
classicZ
    Member
  • PipPip
  • 13 posts
Posted 20 July 2013 - 11:35 PM
Hi all,
My 260z has recently begun to form small, unwelcome puddles of coolant in driver foot well.
Anyway I tracked the leak to this vacuum operated heater tap thing. If anyone has one which they are willing to sell that would be very much appreciated.
Thanks.
Brad
#2 Lurch ™
Lurch ™
  • 5,661 posts
Posted 21 July 2013 - 08:46 AM
Try Nissan.
#3 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 18 September 2013 - 02:42 PM
I have one i picked up on the weekend.
#4 OdinZ
OdinZ
  • 199 posts
  • Tagline:I.....own a car......
Posted 04 August 2017 - 09:55 AM
Hey Gents, instead of starting a new thread, i thought i would hijack this old one. Did you end up finding a replacement all those years ago?
I have a coolant leak in the driver footwell, and when i drove the car home when i bought it, it was also leaking on the passenger side. I took it out for 30minutes a few weeks ago, and I am pretty sure the leak is coming from the heater valve/tap. Just trying to work out my options without spending $200+ on the below item.
http://www.zcarsourc...535_55083.html
#5 gilltech
gilltech
  • Donating Members
  • 1,147 posts
Posted 04 August 2017 - 12:49 PM
But you need to send them a usable core before you can buy it anyway.
You'll have to pull yours out in any case to properly examine it, it's all speculation at present; hopefully it may not be the valve itself but a perished hose.
But if it is the valve then it may be repairable.
If not then the only other thing I can suggest is to buy one, or if necessary a complete heater setup, off a 260Z being parted out.
#6 OdinZ
OdinZ
  • 199 posts
Posted 07 August 2017 - 11:25 AM
Ah right, i should really read the whole add next time. yeah, was trying to avoid pulling the whole heater core out if i could help it, i assume i will need to pull the whole dash out. was trying to avoid that for as long as possible.
cheers
#7 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 10 August 2017 - 07:49 AM
I have heater cores in VGC. PM me. You can also remove the heater box in the 260Z without removing the dash
Scoota
#8 OdinZ
OdinZ
  • 199 posts
Posted 11 August 2017 - 09:16 AM
Scoota
Thanks Scoota, I will do more investigating to work out what is leaking, and eventually pull my heater core out just to see what it's all out. That makes me so happy that i do not need to pull the dash out. haha.
cheers
