Wtd: 240 bits (window, door latch, front discs, etc)
9 replies to this topic
#1 Rod F
Rod F
  • 101 posts
Posted 28 August 2007 - 08:33 AM
Greetings,
I'm after the following if anyone has them:
- drivers side window glass
- drivers side door latch mechanism
- front discs (mine are on minimum thickness)
- horn contact swiper on steering column
- locking nuts that hold the rear shockers in the strut tubes (x2)
- mounting brackets for 260Z retractable seat belts
Thanks!
#2 Rod F
Rod F
  • 101 posts
Posted 11 September 2007 - 05:20 PM
Ok, so most of this stuff is pretty rare, but surely someone is wrecking a Z of some sort and has the locking nuts for the rear struts? I need a set so I can install Koni's i've bought.
If anyone can help, or knows of alternatives it'd be much appreciated. Cheers
#3 zedevan
zedevan
  • 1,347 posts
Posted 11 September 2007 - 05:46 PM
since you live pretty close to it anyway, go up to toperformance and see if they have the nut? they are in trade place in vermont from memory
I'm happy to (sometime) CAD up the seat belt brackets that are in my car (ontop of the longer/higher strut towers) and get some quotes for them being made and powdercoated, although due to the high price of small run's there'd prob a minimum of 5 cars or something so they aren't a complete rip off...or is it another seat belt mounting position that is needed for 240z's?
did nzeder end up coming across some somewhere? or find a cheaper alternative?
#4 pauly_adams
pauly_adams
  • 1,160 posts
Posted 13 September 2007 - 11:33 PM
hey rod i have a near new set of 260z front disk no real wear no scores and i only used them for about 1 month due to a nasty pothole and a frontend change that had decent disk can u use these on a 240z
#5 Rod F
Rod F
  • 101 posts
Posted 14 September 2007 - 01:08 PM
Thanks Pauly, PM sent.
Hey Evan yeah that's a good idea, i've been to them before, just past Rooks rd I think near the Ford Dealership.
That idea about the seat belt mounting plates sounds interesting. Don't worry about powerdercoating, but having them made from scratch would be great.
#6 pauly_adams
pauly_adams
  • 1,160 posts
Posted 14 September 2007 - 08:12 PM
will do ill post it tonight the mesurments and price not at my home at the moment
cheers pauly
#7 pauly_adams
pauly_adams
  • 1,160 posts
Posted 14 September 2007 - 10:01 PM
ok there 10mm to 11mm thick and 270mm in width (from 1 side to the other)
as for price make a fair offer and there yours
cheers pauly
#8 Rod F
Rod F
  • 101 posts
Posted 15 September 2007 - 04:41 PM
Thanks anyway Pauly, i've managed to find some newies
#9 pauly_adams
pauly_adams
  • 1,160 posts
Posted 15 September 2007 - 10:23 PM
its all good good luck wif them
cheers pauly
#10 scoot3r42
scoot3r42
  • 107 posts
Posted 13 October 2007 - 06:44 PM
its the window glass the same as the 260z? im only new to zed just brought my first one yesterday. and have a few parts there and i know i have spare window glass so if its the same as the 260 i have one
