Owens 3.2 build ,starting over
100 replies to this topic
#41 d3c0y
d3c0y
  • 2,906 posts
  • Tagline:Forum Jerk
Posted 29 May 2013 - 12:00 AM
Hope you have lined up a suitable gearbox. I have all but destroyed mine in 4 test drives basically around the greater block...
#42 ZED83
ZED83
  • 134 posts
  • Tagline:73 240z - 83 280zx 2+2
Posted 29 May 2013 - 07:03 AM
I'm getting the full package, Fj20 gear box and R200 lsd diff to suit  ;)
#43 Retro Z
Retro Z
  • 1,404 posts
Posted 29 May 2013 - 10:47 AM
Your going all out!!  Im jealous  ;D
#44 peter mc
peter mc
  • 1,573 posts
Posted 29 May 2013 - 05:43 PM
Getting there now will have it all together tomorrow
#45 ZED83
ZED83
  • 134 posts
Posted 29 May 2013 - 06:22 PM
It's so clean!!!!  ;D coming together nicely.
#46 Lurch ™
Lurch ™
  • 5,661 posts
Posted 29 May 2013 - 07:36 PM
Oh no...! An electric water pump! :(
#47 peter mc
peter mc
  • 1,573 posts
Posted 29 May 2013 - 07:47 PM
yep he had it on the old motor and also has the twin idler lol owell
we are only trying for 310hp , I'm going for a 1308 cam only 298 deg but has 590lift , I'm trying to make as much torque as i can under 5000 , as it will spend all its time on the road , if it was a track car it would have a 654a cam and it would make more over 6000 , and i would change the water pump and do more water mods
#48 ZED83
ZED83
  • 134 posts
Posted 29 May 2013 - 08:06 PM
What's wrong with electric water pumps pete? Is it best to change it!
#49 peter mc
peter mc
  • 1,573 posts
Posted 29 May 2013 - 08:09 PM
I have found on the race motors the EWP is not as good as the stock part , but on your motor i dont think it will be a problem , if we were after 330+ i would as you to change it
#50 peter mc
peter mc
  • 1,573 posts
Posted 30 May 2013 - 05:17 PM
It's just about ready for the dyno .
#51 Gordo
Gordo
  • 1,112 posts
  • Tagline:Racing member.
Posted 30 May 2013 - 05:55 PM
This is looking great. Love the hole setup. Can't wait to see the Dyno results. And Peter did less make those headers or are they SWM headers.
#52 dalee
dalee
  • 406 posts
  • Tagline:The Z Shed
Posted 30 May 2013 - 06:31 PM
Gordo they are modified SWM, shortened secondaries from memory.
#53 peter mc
peter mc
  • 1,573 posts
Posted 30 May 2013 - 06:46 PM
Yer there the new race stroker SPEC pipe, we got sw to make them to our 3.4 SPEC. let's the big motors rpm
#54 Gordo
Gordo
  • 1,112 posts
Posted 30 May 2013 - 07:36 PM
Hey Pete, would my old headers work on the bigger motors?
#55 peter mc
peter mc
  • 1,573 posts
Posted 30 May 2013 - 07:57 PM
We can make your pipes the same Gordo , but its easier to start with a new set , the new pipe has a shorter primary pipe  buy 150mm and fatter second pipe that is shorter as well , when we did Jake's we made 3 sets of pipes and tryed new lengths and size and  these pipes are what we cam out with .
#56 peter mc
peter mc
  • 1,573 posts
Posted 05 June 2013 - 04:38 PM
The new cr fj20t box is done  8)
#57 Riceburner
Riceburner
  • 3,261 posts
Posted 05 June 2013 - 05:19 PM
So much candy! The big headers look shexy. Are the tig welded?
Ooooooh, What's the advantage of this box over a stock 5spd. Are they easy to come across?
This is going to be such a sweet ride Owen  8)
#58 peter mc
peter mc
  • 1,573 posts
Posted 05 June 2013 - 05:32 PM
Gareth the gears set is from kameari , its a 1st 2nd 3rd set and we have fitted a 5 gear so he can cruze with the 4.3 diff ,
for one there a much stronger gear set , and when you fit the big cams you dont want a gappy gear set like most jap boxes 2nd to 3rd is just to wide , and the motor falls off the cam and thats not cool ....  ;D
#59 ZED83
ZED83
  • 134 posts
Posted 05 June 2013 - 06:27 PM
Sweet! at least ill have something that can take my bad driving  ;D  looks great pete  8) ill have the car dropped off this Saturday thought I'd get a set of cohoonies and just do it in stead of getting les to come pick the car up! Lol
#60 Xnke
Xnke
  • 47 posts
Posted 06 June 2013 - 01:35 PM
Mind sharing the ratios there? I just built a box in my floor, that had gear ratios I couldn't find in any Nissan box...Not sure if I scored a rare core or something. Nothing in Nissan USA got the below ratios, nor can I find a listing for any box with the gear widths in this one...2, 3, 4 are all 22mm wide, 1st gear is 24mm wide, input gear set is 22mm wide. 5th gear is still 18mm wide, with a high tooth-count pair...still the 240SX 0.754 ratio but with a third more teeth. Uses a 1997 Pathfinder 4WD synchro kit, but a 2WD bearing kit and case. The 2WD synchros would fit, but didn't allow the gearset to fit into the case...too long.
The ratios in my box are 3.321, 1.915, 1.517, 1:1, 0.754
The third gear...should be 1.308 to make it match with the gearset I was expecting. Second gear should have been 2.088, too...but I checked more times than I care to recall the tooth counts and kept getting the same numbers.
