Owens 3.2 build ,starting over
100 replies to this topic
#21 DatPilot
DatPilot
  • 344 posts
  • Tagline:you are a goose
Posted 27 May 2013 - 07:26 PM
Lovely stuff!
Is it 'sonic testing' to check how far you can bore?
#22 peter mc
peter mc
  • 1,573 posts
Posted 27 May 2013 - 07:45 PM
Hi Owen
More pics off the bottom end, its all together now,  looking  good , i removed all the old paint off the sump and parts that were painted blue and removed the paint from all the bolts to get a better finish , next will be setting up the head with the new springs and cam ,
And yes sonic testing is to see if its safe to bore , as this block was 89.5 it was realy close to getting a new block , but after sonic testing it was found to be a very thick casting
#23 peter mc
peter mc
  • 1,573 posts
Posted 27 May 2013 - 07:49 PM
Just 2 more
Also soda blasted the oil filter adapter so it looks a bit cleaner
#24 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 27 May 2013 - 08:04 PM
Look at those new pistons Owen, yummo  8)
#25 ZED83
ZED83
  • 135 posts
  • Tagline:73 240z - 83 280zx 2+2
Posted 27 May 2013 - 08:10 PM
It's looking fantastic pete  ;D love it! Very happy !!!!!!!! Not wrong scoota, yummo indeed 8)
#26 peter mc
peter mc
  • 1,573 posts
Posted 27 May 2013 - 08:16 PM
There will be Heep's off pics this week , should have the new pipes and i will be finishing the inlet manifold , will be a cracker road race engine , can not wate to get it on the dyno  ;D
#27 ZED83
ZED83
  • 135 posts
Posted 27 May 2013 - 08:24 PM
Sounds good to me. I'm looking forward to the dyno too, to see how we'll it does. Ill be coming down this Saturday I can't wait to see it. :) ill give Les a call tomorrow to confirm.
#28 luvemfast
luvemfast
  • 4,138 posts
Posted 27 May 2013 - 08:36 PM
Don't you just love th ZX oil filter adapters..............  ::)
Why would you put them upside down? So every time you pull it off, oil goes everywhere!  >:(
Looking the goods O
Will we see you on the track?
#29 ZED83
ZED83
  • 135 posts
Posted 27 May 2013 - 09:01 PM
Hay Simon, nah not for track use! Have no time! And after this no money  :D lol just for street fun and the occasional show.
#30 peter mc
peter mc
  • 1,573 posts
Posted 28 May 2013 - 01:31 PM
I finished the intake today ,port matched to the head
#31 pauly_adams
pauly_adams
  • 1,160 posts
Posted 28 May 2013 - 04:36 PM
those are some big injectors for a NA, they appear to be 450cc gtr injectors if im not mistaken
#32 ZED83
ZED83
  • 135 posts
Posted 28 May 2013 - 04:42 PM
Should sound real good now! Pete those mesh filters shouldn't take much to pull off, I've only put three little dabs of silicon to hold them on.  ;)
#33 74zzz
74zzz
  • 533 posts
Posted 28 May 2013 - 05:10 PM
Hey Peter, sent u a pm a while back about piston rod combo.........the spool fj20 rods and the custom sps pistons........ what bore is needed for the combo? remeber you saying you have the piston info on file and have a contact at sps.........Any chances you can PM me the details? or anyone else that has this combo?
cheers!
#34 Gordo
Gordo
  • 1,118 posts
  • Tagline:Racing member.
Posted 28 May 2013 - 05:13 PM
Owen , you are going to love this Engine, when you get it up and running it will be time to do a drive day, or at least meet up some where! Melbourne boys and Ballarat boys and Warrigal  boys and the other Boys.
#35 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 28 May 2013 - 05:28 PM
You were running the sock filters, Owen. What made you switch? Peter told me once the mesh filterss are restrictive. Did I misunderstand you Peter?
#36 ZED83
ZED83
  • 135 posts
Posted 28 May 2013 - 05:33 PM
Sounds good to me Gordo  :) be good to get out of this town for the day! Will have to relearn how to dive it again most likely!
Those injectors are 283cc 14mm!
Hay Roberto,
no! before all this happened I was trying different filters out, but found out by pete also.  :-\
#37 Riceburner
Riceburner
  • 3,265 posts
Posted 28 May 2013 - 05:55 PM
There's quite a few styles of the mesh type, I thought some were good and some were bad. These are EFI hardware one if I'm not mistaken. Steve Newing tested them on a V8, he says they offer no restriction at all and flow the same as an open stack. It's no PMC Lseries so results may vary.
Any filter will have pressure drop across it and that means a flow restriction doesn't it?
#38 ZED83
ZED83
  • 135 posts
Posted 28 May 2013 - 06:12 PM
Hay I'm all for sucking up small birds! Lol ;D mmm KFC
#39 peter mc
peter mc
  • 1,573 posts
Posted 28 May 2013 - 07:54 PM
The dyno don't tell fibs,  i wont have them on any motor i have built .
#40 Riceburner
Riceburner
  • 3,265 posts
Posted 28 May 2013 - 09:18 PM
Lucky I run the socks  :) Lol.
