VIC RWC 280zx problems
21 replies to this topic
#21 Gordo
  • 1,118 posts
  • Tagline:Racing member.
Posted 30 April 2013 - 07:31 PM
I love it Lurch, that sums it up, what a classic. Wheel bearings are easy, take the the bearing cover off with a flat blade screw driver which will expose the big nut on the front axle holding the bearing in .you will have to remove the split pin first. Then tightened the nut with a shifter, do it firm while the disc will still turn freely. Then back it off a quarter turn and make sure the disc has no play in it.that should do it .if as you say they  are running rough, the bearings should be replaced. This is not a big job for a workshop to do. Good luck.
#22 Alibaba
  • PipPip
  • 21 posts
Posted 01 May 2013 - 07:00 AM
Why didnt you just leave your car for that workshop to fix?
They said they don't do it. I'm going to go get some bearings as soon as possible and replace them. Won't be driving till then.
Also I got the rwc  ;D
