NEW OEM H4 headlights
39 replies to this topic
#1 Lurch ™
Lurch ™
  • 5,661 posts
Posted 20 April 2013 - 12:08 PM
A forum service announcement from myself...
These are BRAND NEW, OEM style 'Koito' Brand, H4 headlights.
So now you can still have the factory OEM looking lens, but with the added performance of H4 Halogen (Phillips brand!) globes.
These are a direct bolt in for your 240, 260 & (I think) 280ZX.
A contact of mine informed me that these are available from Toyota dealers (of all places!) for around $100/pair till the end of June (RRP is normally over $250).
So if you want a pair, all you have to do is walk into any Toyota dealer around Australia, and quote the part number: 90981-01H22 Sealed Beam Unit.
If the Toyota spare parts person can't find them on the system, tell them to look harder - they are there! There are over 500 pairs in stock so they wont run out quickly.
(To the blokes who came to the last workshop day, please refrain from disclosing further details of how I found out about these)
Posted Image
Posted Image
Posted Image
  • GongZ likes this
#2 Ledge
Ledge
  • 871 posts
  • Website:http://www.customandclassiccars.com.au/
  • Tagline:PMC RB28
Posted 20 April 2013 - 08:34 PM
yes this is true, i noticed them on my mates cruiser about 3 weeks ago.
got mine tucked away.
#3 PZG302
PZG302
  • 1,761 posts
Posted 21 April 2013 - 03:27 PM
mmm, might check the dealer at Gatton on Tuesday, they would be a great upgrade for the hairdresser car, and I won't tell them either...... ;D
#4 potter260
potter260
  • 233 posts
  • Tagline:Currently enjoying the journey, not yet at the destination
Posted 23 April 2013 - 01:17 PM
Went in today and they quoted me $110 each light?
#5 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 23 April 2013 - 02:57 PM
Gidday,
I have a set and the part number is for one box, but the box has two lamps in it.
You only need order quantity 1
PB
#6 620Z
620Z
  • 1,710 posts
Posted 23 April 2013 - 04:51 PM
So do you need a relay for these? I have one in the Zed at the moment.
Also I have 130watt globes that are like 10-15 years old. Pardon my ignorance but are we saying these will be brighter than what I already have? I was going to put in some new lights to replace the older style? Oh electrical work is not my speciality.  :-\
#7 Lurch ™
Lurch ™
  • 5,661 posts
Posted 23 April 2013 - 04:59 PM
Craigus, these are for people who want to upgrade the std OEM Low Watt lights to H4 spec (while retaining the OEM look).
So in your case, don't bother ;)
#8 potter260
potter260
  • 233 posts
Posted 23 April 2013 - 05:45 PM
Ok i will order 1 box thanks heaps
Mitch
#9 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 23 April 2013 - 05:53 PM
hese would be good for the V8 Zed with the 80amp Holden alternator on a Ford engine with Toyota brakes and Nissan rear discs. HotRod Much?
Thanks for the heads up Lurchous!
#10 nat0_240_chevZ
nat0_240_chevZ
  • 842 posts
Posted 13 May 2013 - 12:56 PM
when i rang they gave me 110 each assy?
got them to check, and they came back with a definate response.....??
nat0
#11 Lurch ™
Lurch ™
  • 5,661 posts
Posted 13 May 2013 - 01:11 PM
nat0
There is 2 lamps in a box, so that would be counted as an assembly.
In which case $110 is about right.
#12 potter260
potter260
  • 233 posts
Posted 13 May 2013 - 04:39 PM
Yeah Thats what happened to me but just order one for $110 and there is 2 in the box.
#13 NickF
NickF
  • 72 posts
Posted 17 May 2013 - 11:30 PM
Why not buy 7" lens and fit halogen globes you can buy from 60 to 120 watts
Should cost between $50-75 even less if you got used lens and new inserts
Nick
#14 Lurch ™
Lurch ™
  • 5,661 posts
Posted 17 May 2013 - 11:44 PM
Nick
I don't think you've quite grasped what this thread is about...
  • VintageNissanEnthusiast likes this
#15 Zedman240®
Zedman240®
  • 5,198 posts
Posted 19 May 2013 - 09:51 AM
These inserts for sale take any H4 globe but don't come with any globes in the box. These are for people with zeds that have original sealed beams that want to upgrade to H4 halogen headlights but with the correct or close to it pattern on the lens that you can't get with the Hella or any other brand H4 insert. Crap loads better than the "Autopal" or Taiwanese or Chinese inserts. These are made in Japan and are of a very high quality. Price probably is $100+GST which makes it $110. These shuold fit in a 280ZX as all 7" round headlight equipped cars mount the same except for late model Ford AU XR series and BMW. Try and not go nuts with higher wattage globes unless you have fitted a relay to the wiring. Even going to a 60/55 in my 240 the switch has melted!
#16 Mooa42
Mooa42
  • 33 posts
Posted 23 July 2014 - 04:07 PM
Just brought a set of these. Our local Toyota dealer had four boxes in stock, Still $110 for a box (1 pair) came with globes too.
#17 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 23 July 2014 - 07:15 PM
While you're at it give serious consideration to adding a relay and tossing in a set 55/100 or 90/130 bulbs.
The relay and brighter bulbs will make the improvement even greater, well worth the extra little bit of effort.
PB
#18 VintageNissanEnthusiast
  • 99 posts
Posted 05 April 2016 - 12:40 PM
I went down to my local dealership today and they gentlemen mentioned that they had some of these in stock. He couldn't disclose if they were semi sealed beams or sealed beams and mentioned that they are flat with no pattern not curved?
He said they had to order them in, and I would have to pay upfront ($121 each, he was adamant it was on in a box) , and if they were the incorrect lamps I'd be stuck as I couldn't return them (as they are electrical). So I decided not to do go ahead today as the guy didn't really have the answers I wanted.
I bought the cheapo "autopal" ones the other day and I do not like the look of them currently, so need to change.
Essentially if I go down, pay the cash and get that exact part number and name "90981-01H22 Sealed Beam Unit" X 1. I SHOULD be in the clear?
Its a costly risk.
Thanks!
#19 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 05 April 2016 - 01:14 PM
Its a costly risk.
Thanks!
Hi mate
Trust me - That part number is a box that contains TWO lamps with 55/60W bulbs.
They are a genuine approved Toyota product and of very high quality.
They are halogen, made of glass, flat fronted and look like the image below when installed.
Edited by PB260Z, 06 April 2016 - 07:14 PM.
#20 VintageNissanEnthusiast
  • 99 posts
Posted 05 April 2016 - 03:40 PM
Ok they look great will go an order them! Did 240's originally come with flat lamps or curved? Either way I will go and order one!
Thanks !
