Epoxy vs Etch primers for bare metal + process
29 replies to this topic
#1 thriller
thriller
  • Donating Members
  • 398 posts
Posted 16 March 2013 - 11:57 AM
Just a bit of blasting left to do tomorrow & I will be ready to prime my engine bay. It's all back to bare metal.
Wondering the process I should go through to get best results... Good clean with wax/grease remover, then etch primer or epoxy primer first? What's the deal there? Lots of conflicting opinions floating around on the google-sphere. Or should etch go down first, then epoxy? Then hi-fill, color and clear?
Thanks.
#2 nat0_240_chevZ
nat0_240_chevZ
  • 834 posts
Posted 16 March 2013 - 01:01 PM
i say Etch, most painters say Epoxy Prime.
end of day metal needs to be cleaned, then sealed.
consult painter involved, and then seek alternatives.
Speak with some older guys then speak to some new younger guys.
opinions differ alot, but the new chem on most products if used correctly do work out a better option.
I use wattyl super etch, more hard wearing than poo15, confirmed independant test in my workshopp on the wire wheel.
its a single pack enamel & compatible with all 2pack primers, I know of.
My opinions based on my own experience.
nat0
#3 mossy
mossy
  • 1,770 posts
Posted 16 March 2013 - 02:14 PM
I used wattle super etch, also rust dissolved the whole car after blasting, took a long time so it was done in sections.
#4 Ledge
Ledge
  • 869 posts
  • Website:http://www.customandclassiccars.com.au/
  • Tagline:PMC RB28
Posted 16 March 2013 - 04:01 PM
Hi Thriller,
The wattyl super etch will do what you need.
I use ppg 2 pack epoxy etch on customers cars.
Paul
#5 chris240
chris240
  • 2,186 posts
Posted 16 March 2013 - 05:25 PM
100% etch primer...
Also try to use the dulux prepsol rather than a garden variety acetone ......just spent the arvo high on acetone fumes  :o :o :o
Where very Lucky this forum has some gun sprayers....no pun intended.  8)
#6 thriller
thriller
  • Donating Members
  • 398 posts
Posted 16 March 2013 - 06:18 PM
Thanks for you expertise all.
Have a tin of white knight SLS etch primer unopened. Will that do the trick or try to return it and go for the wattyl stuff?
#7 Retro Z
Retro Z
  • 1,398 posts
Posted 16 March 2013 - 06:21 PM
Theres a product out called Clausens 'All u need' Which is basically a etch, filler, primer, guide coat in one.
I've had much success with it and makes it much much easier as it can be kept in that state and doesnt absorb moisture over time. And compatible with all top coats i believe. Not cheap but simplifies things alot.
#8 nat0_240_chevZ
nat0_240_chevZ
  • 834 posts
Posted 16 March 2013 - 10:03 PM
yes, i also forgot the 2 pac etch epoxies, also a very good option, PPG & sikkens one I DO have first hand exp with, (but must have forgotten, must of not worn a mask!@#$)worked and sanded really well as they have quite a bit of build for what they are.
although stay away from one brand i came accros, its 2 pac etch was able to be slowely wiped off with thinners, (which 2 pach should not) cant remember brand But ill report back.
nato
#9 fluegel
fluegel
  • Donating Members
  • 108 posts
Posted 17 March 2013 - 11:02 AM
I prefer to use wattle super etch. You can use the dilute phos acid before priming i would like to know is it OK the use super etch over metal which has been treated with phos acid such as removing surphace rust after mollassas solution treatment.
Richard
#10 zed74
zed74
  • 402 posts
Posted 17 March 2013 - 07:37 PM
I have had good experience with debeer epoxy primer :)
used it straight after sandblasting - POR 15 on rust repair sections/repair work following the sandblast/epoxy prime
#11 nat0_240_chevZ
nat0_240_chevZ
  • 834 posts
Posted 17 March 2013 - 10:09 PM
wattyl is a phos based etch!!!
the one to stay away from i mentioned above is standox 2pac etch.
Wattyl is said to be the best, and i tend to aggree, sticks like shit to a blanket and its adhesion is f*&^n awesome.
as i have done these 'wrie wheel' test on my bench grinder. tough as, even though i thought it would not do to well only being a single pack etch.
but it is compatible with all 2k prods.....appearantly.
Nat0
#12 imackz
imackz
  • 239 posts
  • Tagline:v8 into a 280zx makes 450zx
Posted 18 March 2013 - 02:42 AM
Thanks.
Upol make a great poly primer & high filler gets a great finish.
#13 showtime
showtime
  • 35 posts
Posted 30 July 2013 - 09:46 PM
For bare metal i use 428 EX BARRIER PRIME by ppg .it IS A  2 pak ZINC PHOSPHATE EPOXY PRIMER FOR "WET ON WET". it flows on nice and the finish is semi gloss, and it comes in dark grey, white. The hardener is ex-9090 I haven’t had any trouble with this product, then ya ready for bog, polyester spray filler, primer, base coat, clear coat.
#14 Rat1314
Rat1314
  • 108 posts
Posted 12 August 2013 - 01:37 PM
Been hearing a lot of people recommend the Wattyl etch primer. I just have two questions about it though. First one is where do you buy it from? Is it just at Bunnings or would I need to find a paint supplier who stocks it? Also can you apply a body filler over the top of the primer?
#15 Rat1314
Rat1314
  • 108 posts
Posted 12 August 2013 - 04:33 PM
I've already answered one of my own questions. A quick look on the Wattyl web site and I've found a few distributors close by
#16 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 19 November 2013 - 08:37 AM
FYI, I just bought Wattyl Super etch and read the data sheet:  It IS an epoxy self etching primer.  So the question of one or the other is not necessary.
SUPER ETCH
TM1.50
Version 2, January 2010
DESCRIPTION : a premium quality, single-pack epoxy etch primer
It doesn't say whether body filler can be applied on top of it or if so within what time frame.
#17 24TZ
24TZ
  • 93 posts
Posted 17 September 2014 - 11:34 AM
SUPER ETCH
TM1.50
I'm also keen to know if body filler can be applied over the wattyl super etch?
#18 Roberto
Roberto
  • 740 posts
Posted 17 September 2014 - 01:10 PM
Apparently body filler can be used over all primers, but surface must be sanded with coarse grit paper so that it bonds to it strongly.
#19 gav240z
gav240z
    Administrator
  • 12,384 posts
Posted 17 September 2014 - 01:17 PM
Interesting, at my tafe course they tend to apply the filler to the metal and then paint over it.
#20 Patch
Patch
  • 349 posts
Posted 17 September 2014 - 01:44 PM
That is old school way Gav, mine is done like that and most of the bog that was done 20 years ago has fallen off with rust behind it, can show photos if needed,  supposedly the heat reaction causes the bare steel to sweat, that is why new school do it on top or  etch primer.
