Gears not changing
12 replies to this topic
#1 vramjee91
vramjee91
  • 174 posts
  • Tagline:live my life a quarter mile at a time
Posted 21 February 2013 - 07:50 PM
Hey guys,
I have put a 280zx gearbox onto an L26, I filled everything up (Clutch, engine, gearbox etc)
However when I try to change gears, the gears wont change. I am not sure why this is the case. The only thing I can think of is the fact that I used the clutch bearing holder (mounts onto the fork) from a 240z gearbox.
Am I missing anything?? Is this the case??  Help please?
#2 Retro Z
Retro Z
  • 1,398 posts
Posted 21 February 2013 - 08:01 PM
Has the clutch been bled?. Is the slave cylinder piston pushing against the fork?
Was the fork installed correctly and bearing greased? Sounds like its not disengaging.
#3 Linton
Linton
  • 517 posts
  • Tagline:1976 260z 2+2 Sunburst 1989 300zx Z32TT 2+2 Black
what does does clutch pedal feel like ? can you change gears with the engine off? you will need to elaborate a lot more to get an answer, might just need to bleed the clutch have you done that?
#4 vramjee91
vramjee91
  • 174 posts
Posted 21 February 2013 - 08:08 PM
Hey guys,
Thanks for the responses.
I have bled the clutch a number of times, I can change the gears when the car is off. The pedal feels a lot more resistant now that I have bled the clutch.
The clutch fork was greased, and the pin moves, however im not sure if it moves far enough to be able to change the gears.
Anymore info you guys need?
#5 Linton
Linton
  • 517 posts
Posted 21 February 2013 - 08:30 PM
get a second person to operate the clutch, pop under neath and look at the position of the fork arm it should be fairly close to touching the gearbox when the clutch is fully depressed,
#6 d3c0y
d3c0y
  • 2,847 posts
  • Tagline:Forum Jerk
Posted 21 February 2013 - 08:40 PM
What sort of oil did you put in the box?
#7 Retro Z
Retro Z
  • 1,398 posts
Posted 21 February 2013 - 09:33 PM
You can also wind out the piston on the clutch slave cylinder with pliers to allow more pivot on the clutch fork.
#8 dat2kman
dat2kman
  • 4,029 posts
Posted 21 February 2013 - 10:10 PM
Clutch fork throwout bearing carrier are different heights.
If you cannot introduce an adjystable slave pushrod, you are going to need to R&R the box, either fit a taller carrier, or machine a spacer ring to project the thrust bearing out further, about 3-4 mm will do it.
#9 vramjee91
vramjee91
  • 174 posts
Posted 22 February 2013 - 12:15 PM
Cheers guys for all the info!
I defiantly think it is the bearing collar, as it was from an early 240z box
The question now is, can I extend the pin on the slave cylinder? if so how?
Or where can i get a 280zx collar??
Cheers guys again, and the oil i used was general transmission oil from autobarn
#10 d3c0y
d3c0y
  • 2,847 posts
Posted 22 February 2013 - 04:19 PM
You can just find a bolt the right length and linish the ends so they are round.
Did you check the weight of the oil? Looks like you have identified the problem though.
#11 vramjee91
vramjee91
  • 174 posts
Posted 22 February 2013 - 09:25 PM
Hey guys,
Which ones of these two would recommend?
http://www.thezstore.../SCCB08/21-2123
http://www.thezstore.../SCCB08/21-2122
#12 vramjee91
vramjee91
  • 174 posts
Posted 22 February 2013 - 09:27 PM
Yeh,it was the recommended one from the transmission fluid manual.
Thanks tho
#13 pauly_adams
pauly_adams
  • 1,160 posts
Posted 22 February 2013 - 10:11 PM
yeh the bolt works well  ;D , if you drill the clutch fork you can weld a nut onto it, then you can adjust as you wish
