Author Topic: Some more cool Z videos - youtube.com  (Read 10461 times)
Offline NZeder
  • Registered User
    • http://nzeder.net
Re: Some more cool Z videos - youtube.com
« Reply #75 on: November 14, 2009, 02:13:42 PM »
Fairlady Z from Japan with a RB30DE installed - twin exhaust setup - this is sim to how my will be setup so I hope it sounds like this too ;)
http://www.youtube.com/watch?v=6DnM3RIKSIM
76 RS30 260z 改RB26 N/A 霞
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline zzzzed
  • mick the zed freek
  • Registered User
« Reply #76 on: November 17, 2009, 09:06:49 PM »
370z v mustang
the 370z easily out performs the mustang
http://www.youtube.com/watch?v=AfmkwY-Q_oM&feature=rec-HM-r2
some people are like Slinky's, quite useless but funny to watch when you push them down the stairs
z31 300zx cafe
240z in the making
Offline Cdr Zero
  • Akio Asakura
  • Donating Member
  • Registered User
« Reply #77 on: December 13, 2009, 10:18:57 AM »
Another Z cleaning up on the track in Japan
http://www.youtube.com/watch?v=8DU-Vs-MWz8
HS30103643
Offline WogsRus
  • Donating Member
  • Registered User
  • New Member
« Reply #78 on: December 13, 2009, 03:00:53 PM »
dam that thing is QUICK. dam it. what's in it
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #79 on: December 13, 2009, 03:31:13 PM »
Here are some more of the same car
http://www.youtube.com/watch?v=rXI_cX0Y_j0
http://www.youtube.com/watch?v=Bce26r3f7No
http://www.youtube.com/watch?v=IVK5uL5KLs4
http://www.youtube.com/watch?v=mS_knfnX-Pw
and this one with a stronger field including a Nissan R380 Le-Manns car :)
http://www.youtube.com/watch?v=oTWXSr3ydv4
Now about the car and what is in it - I can answer that as I have Japanese magazine article on it.
First before we get to the engine lets understands other aspects of the car.
RIMS are Longchamp XR4 in 15x9 -15 offset fronts and rears are 15x9.5 -21 offset. Rapped in 215/50/15 front and 225/50/15 rears both Advan A048 (yes it has ZG overfenders installed and a large wing on the rear front spoiler is the normal single piece setup and it has light covers with chrome rings). Front brakes are the good brembo 4 pots and rear are also the good brembo 4 pots. These run with an AP adjustable valve and no booster but still a single MC. Fitted with a bolt in half cage. Running 260z (as we know them) stub axles in the rear - not sure on the diff or gearbox setup.
Ok the engine.
It runs a surge tank and 2 pumps - assume pre and post surge tank. A thick cross flow raditor. On the side of the engine are 3 x 50mm mikuni carbs running open trumpeted feed from air taken from in front of the radiator (ie 3 or 4" pipe fitted via radiator support panel). Under these sucky things is a wrapped header that is 45mm and 6-2-1 design. Still running a Dizzy but electronic and controlled by the Wako CD-1200 CDI unit. Now for the engine inside bits.
An L3.0 running 89mm bore and a 80mm stroke (ie L28 crank offset ground or smaller journal to add the extra 1mm stroke - that is an assumption on my part) running standard 44mm inlet valves and 35mm exhaust with a 78 cam (this is what I can make out of the Japanese Kanji) which is 12mm of lift I think. And what I think is an AP twin plate clutch setup (again my Japanese Kanji is no existent so this is my best guess)
So does that help?
« Last Edit: December 14, 2009, 05:32:19 AM by NZeder »
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline Cdr Zero
  • Akio Asakura
  • Donating Member
  • Registered User
« Reply #80 on: December 14, 2009, 05:11:37 AM »
Thanks NZeder  :)
HS30103643
Offline WogsRus
  • Donating Member
  • Registered User
  • New Member
« Reply #81 on: December 14, 2009, 08:31:41 AM »
Dam, as long as my L26 sounds like that i'll be happy. Love teh amount of drive he can get out of teh corners, i think it's a very soughted car.
Any idea on Hp figures?
Offline NZeder
  • Registered User
    • http://nzeder.net
« Reply #82 on: December 14, 2009, 09:31:19 AM »
Re the drive out of the corner - found the spring rates 11kg/mm and 12kg/mm (616lb/in and 672lb/in) no wonder it sits so flat that thing must hardly move.
Re the power output - no figures indicated but if other correctly build 3.0l are used as a guide it should have 250-280ps at the wheels.
Previous
70 HS30-00016 240z
72 HS30 240z L型 2.8
71 HS30 240z L型改3.2
79 HS130 280zx
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
Offline Cdr Zero
  • Akio Asakura
  • Donating Member
  • Registered User
« Reply #83 on: December 16, 2009, 06:13:31 PM »
90's Japanese Tuner showdown including the Excellent Speed S30Z (love their names!) showing the young'uns a thing or two!  Until the incident that is.  :-\
EDIT: Mind the random panty shots.
Part 1
http://www.youtube.com/watch?v=n61WYPqgHJM
Part 2
http://www.youtube.com/watch?v=LPpxkgpXmtk
« Last Edit: December 16, 2009, 06:20:05 PM by Cdr Zero »
HS30103643
Offline Gareth. J.
  • Donating Member
  • Registered User
« Reply #84 on: December 16, 2009, 06:52:56 PM »
There's no way i'd go on the track with those nutters, you'd end up getting shunted into the fence! hehehehe.  Love the 240z off the start line  8)
Offline gav240z
  • Gavin (Auszcar Webmaster)
  • Administrator
  • Registered User
    • Datsun 240z Project
« Reply #85 on: December 31, 2009, 04:24:28 AM »
1972 Datsun 240z
Offline mossy
  • Registered User
« Reply #86 on: January 03, 2010, 06:39:55 PM »
Some cool classics in this one
http://www.youtube.com/watch?v=bf2ZNeb0Ctw
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #87 on: February 07, 2010, 03:24:44 PM »
I'm an Ar#ehole of a Moderator - DEAL WITH IT.
HS30-00149 "Early Girl"
http://www.viczcar.com/forum/index.php/topic,7104.0.html
Offline Stivva
  • Donating Member
  • Registered User
  • Hooning in my 260z 2 seater
    • Photomotive
« Reply #88 on: February 11, 2010, 09:59:03 AM »
Offline gav240z
  • Administrator
  • Registered User
1972 Datsun 240z
