53-681 Posted February 28, 2012 Posted February 28, 2012 Hello dear Z enthusiasts, I am currently under a massive dilemma... My 260Z is currently fitted with 240Z carburetors, E41 balance tube, trumpets and socks, etc. My fuel consumption is still about 160KM's on the full tank running BP/Mobil Unleaded Octane 95... 98 is worse, about 120KM's. What could be the problem??? Surely this is not the fuel economy of a stock L26... Quote
peter mc Posted February 28, 2012 Posted February 28, 2012 No that's not normal your carbs need to be looked at most likely worn in the tubes the needles run in and running very rich have it checked out by a zed man in melb or come down to Les collins racing , daz in melb will fix it for you if you don't wont to come out to the sticks Quote
53-681 Posted February 28, 2012 Author Posted February 28, 2012 Had these carbs re-built with brand new kits and brand new hoses... Maybe if I pull the hoses off? Coz I seem to be having a similiar issue with the thread before mine, where if I floor the pedal to full throttle, There is hardly any response, and after flooring for a 10 secs or so and stepping on the clutch - It STALLS! Quote
Administrators gav240z Posted February 28, 2012 Administrators Posted February 28, 2012 Who rebuilt your carbs for you? Got pictures of them? I've heard of people getting "240Z" carbs that were not in fact 240z carbs. Your lack of excitement when hitting the loud pedal could be an ignition issue. What colour are the spark plugs? Take some pics of these items perhaps? But honestly it's hard to tell you what's wrong without a bit more detail. - Do you have an electric fuel pump? - When was the filter changed? - What kind of distributor do you have stock? - What condition is the rotor button, points, distributor cap, leads, plugs in? Engine bay pic would probably be the best. Quote
peter mc Posted February 28, 2012 Posted February 28, 2012 just because some one put new gaskets in them does not mean there rebuilt ...... take it to a zed man and have him look at it Quote
Scoota G Posted February 28, 2012 Posted February 28, 2012 I'm going to say the float levels need adjusting. You should be getting about 380 Kays per tank! Quote
DAZDA Posted February 28, 2012 Posted February 28, 2012 By 240Z carburettors I assume you mean the Hitachi SU-Style carburettors Unless there is an actual fuel leak (split fuel line, hole in the tank, etc), excessive fuel consumption with these carbies is usually one of the following; Incorrectly adjusted needle tube height there is a big mixture adjustment knob under each carby. Generally, the closer the seat (needle tube) is to the needle the leaner the mixture will be overall, and vice versa. To get the mixtures 'right' like you can do with EFI would normally require different needle profiles (different needles) but you should be able to get it reasonably close with the adjustment knob Too much fuel getting past the needle and seat which is usually incorrectly adjusted float levels (too high) as Scoota G suggested Fuel Bowl(s) overflowing usually one of the floats is no longer floating. I have experienced this a few times with the brass floats. Replace the float with one that does, reset the float level and this should be fixed Quote
chris240 Posted February 29, 2012 Posted February 29, 2012 And while your looking for a zed carbie man, also look for a hairdresser I was able to get 400kms plus on hwy cycle. Quote
lightmaster240z Posted February 29, 2012 Posted February 29, 2012 Tune up with some that know what is going on will make all the difference to the car and the number of a good lawyer is sue who ever cut your hair This should fix all these problems. Bruce Quote
Administrators gav240z Posted February 29, 2012 Administrators Posted February 29, 2012 If you're a DIY guy I highly recommend: The JUST SU's video http://www.ztherapy.com/ http://www.ztherapy.com/products/videos/just_SU.htm They sent me a copy a while ago and it literally covers everything and is cheap to buy also. You'll know how to get the most from your S.U carbs after watching this. Quote
pauly_adams Posted March 1, 2012 Posted March 1, 2012 well i get 500+ km out of my tank in my 2+2 with a 55L tank so there, what i would be doing is first check your timing, then check your float level, then fuel pressure as it may be miles too high, then check mixture screws what you can do is tighten them all the way in then take them out 3-4 turns make sure there even. after that balance them you can use a piece of 4mm hose in your ear to help you hear the vacume, after all this adjust idle then recheck if you get them sweet you should get awsome power all through your rev range. hope this helps cheers pauly Quote
MaygZ Posted March 1, 2012 Posted March 1, 2012 If you're a DIY guy I highly recommend: He is with hair cuts! ... where if I floor the pedal to full throttle ..... There's part of the fuel consumption problem. I strongly suspect your spark. How old is that coil?? pull off a lead and check the spark. It should be able to jump about 5-6 mm easily and be able to be heard and seen during the day. If you have that - and I doubt it by the look of your coil - then check the heat range and gap of your plugs. Finally check your dwell and timing. Once you have all of these spot on, then start looking at your carbs just as Pauly described. But before you do anything else .. and this is very important ... before you do anything else what-so-ever .... get a frickin' hair cut!!! You look like a Bozo. Quote
53-681 Posted March 1, 2012 Author Posted March 1, 2012 lol. Spark plugs are brand new NGK Iridiums... Coil is old and I will gladly appreciate a brand new 280ZX digital coil Quote
luvemfast Posted March 1, 2012 Posted March 1, 2012 Yes you have new plugs. But what type? From memory, I have 5's in mine. Your economy is worse than my triple 44PHH Mikuni's You mentioned you had them rebuilt. By who? They're 1 3/4" right? This was done as your 2" ones were usin too much fuel right? See the pattern? May not be your carb's alone. Take it to someone who knows what here doing. Do you have Daniel Moore's details? Quote
Enzo Posted March 1, 2012 Posted March 1, 2012 Hi Bozo, From your pictures it looks like you are running the N36 inlet manifold with the vacuum fittings behind the first carb. You have 2 hoses attached from the manifold to what looks like the suction chamber air inlet on the face of the carb behind the filters. The suction chamber inlet should be drawing air into the carb at atmospheric pressure. What the picture shows is vacuum drawing against the dampener. Remove the hoses and block off the 2 vacuum fittings at the manifold. On the diagram No 5 shows the direction of air flow. Regards David Quote
53-681 Posted March 2, 2012 Author Posted March 2, 2012 If I don't pull them off now, will I cause any damage? Coz I drive it out to work and weekend nights... Its rendering me so paranoid that I can't even dance properly at the clubs anymore I wanna be again Quote
PZG302 Posted March 2, 2012 Posted March 2, 2012 lol. Spark plugs are brand new NGK Iridiums... Coil is old and I will gladly appreciate a brand new 280ZX digital coil No need to use the expensive iridiums, the NGK BPE6, or 5 is all you need and only about $5 a pop. At worst you may need to go to a 7 depending on the state of your motor, ie higher compression and the timing you run, but standard motor 6's would be were I would start with plugs. Quote
Enzo Posted March 2, 2012 Posted March 2, 2012 Bozo,remove the hoses so you don't have vacuum at the carb. This should be vented to atmospheric pressure. Quote
53-681 Posted March 3, 2012 Author Posted March 3, 2012 Just remove all the hoses? Will it improve things like performance and fuel economy? Quote
260Coupe Posted March 4, 2012 Posted March 4, 2012 Bozo The hoses from the top of the float cambers should be vented to atmosphere (they are usually connected to the back of the stock air cleaner housing so fuel vapour is drawn back through the carbs), by having them connected to inlet vacuum this would caused the float chambers to flood and fuel to be drawn directly into the inlet - which would have caused the flooding and the high fuel consumption Disconnect the float bowl vent hoses, plug the inlet vacuum nipples if they are spares (these should be used for the vacuum advance to the distibuter) - retune the mixture - from the large knurled knob under the carbs and test drive Even better - get it dyno tuned by an expert to ensure your needles suit the engine capacity PM me if you want the contact details for an Hitachi tuning expert with a dyno BTW Well spotted Enzo Quote
dazzed Posted June 12, 2012 Posted June 12, 2012 lol. Spark plugs are brand new NGK Iridiums... Coil is old and I will gladly appreciate a brand new 280ZX digital coil forget the iridiums not going to do you any favours now you have the right induction system for the street get it sorted by someone familiar with tuning zeds with this set up Quote
