T.A.P Posted September 30, 2011 Posted September 30, 2011 Does anyone else has problem with their weatherstrips from MSA? After fitting the door weatherstrips I cant close the doors so I had to cut a portion of the outer strip from the driver side kick to the middle of the datsun kick plate. I still cant close them properly unless I use excessive force and slam it, and I mean really slam it. Hopefully the strips gonna "settle" in otherwise the doors gonna fall off soon... Quote
Quandary Posted September 30, 2011 Posted September 30, 2011 Same issue, and I bought these years ago. I would advise not slamming the door and thinking it will settle. I did exactly this but now my driver door always looks out of place, and still doesn't close fully without a bit of force. If you slam the door wind your windows down first as it seems to put more weight in the right area. Quote
T.A.P Posted September 30, 2011 Author Posted September 30, 2011 I think they will settle, after cutting abit off the strip I was able to close them but they werent flush with the body and were hard to close. However they seemed easier to close today so I cut a little more where the rubbers sort of "swashed in" because of being tightly sandwiched between the door and the body, I moved the latches abit to the inside of the car and now the doors are flush with the body. Still hard to close but they are flush. I'll wait for a month or so and see how it goes. If the slamming continues I'll order some strips from Scott's, just received some for the quarter windows and hatchs strips and his rubbers are softers than MSA's. Quote
ackent1 Posted September 30, 2011 Posted September 30, 2011 Installed these nearly a year ago, and there still tight! Door sits proud a few mm at bottom or the door, Might get a set from scotts as well if there better! Adrian Quote
Z Posted September 30, 2011 Posted September 30, 2011 I've got the same issue with mine too, had them in since about a year ago. The car has not had much driving but the driver's side should be better by now, got mine from All Z Parts, I could be in for a set too if they are better suited. Quote
chris240 Posted September 30, 2011 Posted September 30, 2011 Ive always liked the quality from Scotts... every order Ive had off them has arrived inside Coco pops boxes Quote
mossy Posted September 30, 2011 Posted September 30, 2011 Checkout classiczcar, some guys have been using kia sportage weatherstrips with good results. Quote
handsandwhich Posted September 30, 2011 Posted September 30, 2011 People have been complaining about the fitment of those for ages now and I'm surprised they haven't done anything to fix the issues. I have also gone the Kia Sportage route and got one to try out. I haven't fitted it yet but it does have a nice snug fit and you can also use one in the hatch area. gav240z 1 Quote
Roberto Posted October 1, 2011 Posted October 1, 2011 There was a delay of being able to get these kits and I read somewhere that they were sorting out this door rubber issue. Are these recently purchased kits? If so I am going to steer clear of these. Scotts are meant to fit well. Quote
T.A.P Posted October 1, 2011 Author Posted October 1, 2011 They are recent purchase. Yea Scott's rubbers are very good, soft and perfect fit. Quote
Z Posted October 1, 2011 Posted October 1, 2011 So this would be Scott's page for Z's, the prices are pretty good: http://www.scottsoldautorubber.com.au/Datsun%201969-78%20240Z-260Z.htm Quote
Agno Posted October 2, 2011 Posted October 2, 2011 So are Scott's rubbers only good for door parts or are all of his parts of high quality? I would like to source all of my rubber parts from the one supplier if possible. Quote
T.A.P Posted October 4, 2011 Author Posted October 4, 2011 Rear quarters and rear hatch and the outer strip of the rear hatch are good, I have not try any other. Actually if you trim off the outer rubber of the MSA's (just the under half) the doors close very well, no out of place and no slamming. Quote
Agno Posted January 16, 2012 Posted January 16, 2012 Thread bump! I installed door weatherstrips from Scott's Old Auto Rubber. Really easy to install and nice and soft but the closing efforts are huge! Will this settle over time? At the moment I'm having to close the door to the first latch point and then leaning on the door fairly hard to close it... and then I can barely pull the handle hard enough to open it! Quote
Six_Shooter Posted January 16, 2012 Posted January 16, 2012 I have the Kia door rubber on my 240Z, and like them a lot. Seal well, holding the door firm, without needing to use excessive force to close the doors. For my hatch, I used a 4th gen Chevy Camaro hatch seal. It needed to be cut shorter, and took a but of effort to close tye first few times, but works well. I don't onow what the Aussie equivilant would be for that part. Quote
handsandwhich Posted January 16, 2012 Posted January 16, 2012 You can use the kia door rubber in the hatch as well. It fits perfect and no trimming whatsoever is needed, it stays in one complete piece and needs no glue to stay in place. gav240z 1 Quote
Agno Posted January 17, 2012 Posted January 17, 2012 Do you have anymore info/links on this Kia seal? Sounds interesting Quote
handsandwhich Posted January 17, 2012 Posted January 17, 2012 I did have the part numbers written down somewhere, will have to look for them again but here is a pic of the door rubber fitted in the hatch. gav240z 1 Quote
kobes Posted January 17, 2012 Posted January 17, 2012 You can use the kia door rubber in the hatch as well. It fits perfect and no trimming whatsoever is needed, it stays in one complete piece and needs no glue to stay in place. Like seriously how does one even find that out....... Quote
d3c0y Posted January 23, 2012 Posted January 23, 2012 I got these same seals from Rare Spares like 10 years ago, they are generic holden seal too. I had the same style on my hatch and found it was a bit too tight though. http://www.ebay.com.au/itm/VN-VS-Holden-Commodore-Front-Rear-Door-Seal-GREY-/300636745258?pt=AU_Car_Parts_Accessories&hash=item45ff58ae2a VN - VS commodore seal is the same... Quote
